AC line leak question?
Old Jul 14, 2003 | 03:36 PM
97 RedSS's Avatar
The bottem AC line that runs parallel to the passenger side valve cover is leaking..It is the one on the bottem and has a connector on it...the line goes straight to the evap.
The leak is a small pin hole leak that was cause from my AIR tube rubbing against it..
Would it be OK to JB weld this hole??
Cody
Old Jul 14, 2003 | 03:48 PM
BlackDog's Avatar
No it won't. I had a pin hole on the evap. It only lasted a week.
Old Jul 14, 2003 | 05:59 PM
slverbullet's Avatar
yeah, i had a leak in the same spot. i'd suggest getting a new line from gmpartsdirect.com. i replaced mine a few months ago and it runs great. i think theyre $80. it wasnt a real difficult install either. took me about an hour and a half. and that was because half the time i was trying to find a way to get the old line out without removing the compressor (by the way, it doesnt work. and if it did, you would still have to remove it to get the new one in). plus the new line comes with all the new gaskets you need. hope this helps.
dave
calaban
May 18, 2020 06:43 PM
Feffman
Oct 9, 2015 05:42 AM
pologreen97z
Dec 2, 2014 10:42 AM
blac94Z
Nov 28, 2014 01:53 PM
