Car will not start, Air bag??
Old Jul 14, 2003 | 01:34 PM
DrDUKE's Avatar
Ive havent had trouble starting ever, now its got nothing. When i crank it flashes INFL REST which i imagine means inlfation restraint so air bag. Its got juice its charged, But when you turn the key nothing. It flashes INFL REST again
HELP
Old Jul 14, 2003 | 01:51 PM
DrDUKE's Avatar
The Security light comes on too. It sounds like the silonoid is clicking but no start. It is almost like somthing is keeping the power from the starter. The security system was supposible disabled and hasnt been used in years. I dont know what is up now.
Old Jul 14, 2003 | 06:08 PM
Damon's Avatar
THe air bag system is not linked to the rest of the vehicle- it's stand-alone. It won't prevent the car from starting.
If someone disabled the VATS (security system) and it's now gone active again for some reason that could prevent starting. You won't even get a click.
Check your park/neutral switch before you freak out. Try starting in Neutral or jsut jiggling the gear shift- if that's the problem you can often get it to start if the switch is just getting a little flaky. If it's bad, likewise, you won't even get a click.
Old Jul 14, 2003 | 11:09 PM
DrDUKE's Avatar
well after some time it just up and started. I would like to look into the park/neutral switch, but i never heard of one. BTW this is my first automatic...ever.
Old Jul 15, 2003 | 08:00 AM
Damon's Avatar
On a 3rd gen I beleive it is actually near the shifter itself, inside the console. Once you see it, it's operation should be pretty self-explanatory.
Old Jul 15, 2003 | 06:28 PM
TheGreatJ's Avatar
Can you hear the solenoid click when you try to start it? If so then you probably just need a new starter.
Britbilly
Jan 7, 2015 08:49 PM
97SSdude
Dec 31, 2014 07:43 PM
USAirman93
Nov 24, 2014 03:37 PM
Jul 4, 2005 05:00 PM
