Best gears for my car?
Old Jul 14, 2003 | 06:19 AM
94FBODY's Avatar
I just bought my 94 z28 last week and i was wondering what the best Gears are to get? what have people had the best results with? Thank guys.
Old Jul 14, 2003 | 08:34 AM
bandit1's Avatar
First off welcome to the board! With your car being an A4 you probably already have either 2.73 or 3.23's. If you have 2.73's (as I do ) any 3 series gear is going to make a big difference. I'm personally going with 3.42's in my car because I'd like to maintain a little of my current gas mileage but want some performance! A lot of people say 3.73's are the highest A4's should go, although other have went with 4.10's and love them. It's all up to you!
3.23's & 3.42's= decent performance and good mpg
3.73's= better performance, traction issues, and decent mpg
4.10's= performance, traction issues, and mpg!
BTW, you will also need a series 3 carrier if you are going from a 2.73 to any 3.** series ratio!
Hope this helps!
Later,
Mike
PS. Run a search about gears and I'm sure you will find many opinions on what works best with different set-ups! Good luck!
Old Jul 14, 2003 | 03:44 PM
94FBODY's Avatar
Hope this helps!
Later,
Thanks for all the info, you have been very helpful.
Mike
Old Jul 14, 2003 | 04:46 PM
revtime's Avatar
I ran 3.73s with a lightly modded LT1 (CAI, catback, shiftkit)
and traction was a big issue.
If I mashed the throttle from a dead stop it would not hook up till about the middle of second gear. They work great and I think you would love em but you will probably need to address the traction problems you will run into.
Old Jul 14, 2003 | 05:28 PM
MentalCaseOne's Avatar
Amen for the Traction problem. My 95 almost stocker A4 Lites up the tires from a dead stop and I have the the 2.73s gears.
I will work the traction part even before I change my gears.
Oh did I forget to tell you I live in Hawaii and the Weather is hot and almost humid? I can only imagine what cold weather.. cold pavement.. and 4.** gears driving could be.
Work your traction first so when you get to the gears you will enjoy the driving as opossed to the sliding.
Marvin
97SSdude
Dec 31, 2014 07:43 PM
ChrisFrez
Dec 21, 2014 09:47 PM
ChrisFrez
Dec 15, 2014 03:09 PM
tds1213
Nov 27, 2014 12:55 PM
USAirman93
Nov 24, 2014 03:37 PM
