high impedence injectors?
Old Jul 12, 2003 | 02:04 PM
MadMaxz28's Avatar
im looking for some 36lbers on ebay and most say high impedence.. is that the right stuff?
Old Jul 12, 2003 | 02:19 PM
anaik's Avatar
Stock injectors are high impedence. You're on the right track.
Old Jul 12, 2003 | 02:42 PM
kmook's Avatar
Advanced Tech Moderator
Yep HighZ are the only thing the stock ecu can use. To use LowZ you need an aftermarket ecu or an imp converter. LowZ are usually 50lb+ injectors.
Old Jul 12, 2003 | 03:06 PM
MadMaxz28's Avatar
ahh thanks. now there are 2 sets of 36's and a few sets of 30's on ebay. i think the 30's will be cutting it close once i do the 150 shot but im not sure. i dont even know if im gonna spray a wet or dry shot. the guys at my shop like dry.
will these work? or just go with a new set of 30's
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2423288337
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2422835822
thanks again!
Old Jul 12, 2003 | 03:19 PM
Josh-'04 GTO's Avatar
I'd go with the 30's if I were you and use a wet shot on the N2O. Get the injectors and spend some time on a dyno with a wideband O2 sensor and get your A/F dialed it.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
moneyshotz
Jul 27, 2002 06:16 AM
