What belt will replace the serpentine and bypass the power steering pump?
Old Jul 30, 2002 | 05:38 PM
jp2002ls1's Avatar
Post What belt will replace the serpentine and bypass the power steering pump?
I need to know in a hurry what belt I can buy to bypass the power steering pump? Also will this hurt anything if I do this only at the track and how much will I gain?
2002 basically stock engine ls1
Old Jul 31, 2002 | 09:09 AM
jp2002ls1's Avatar
Post
I would greatly appreciate it if anyone could tell me what size belt or the part number of a belt that will fit on my 2002 ls1 and bypass the power steering pump yet still run from the crank to the water pump and alternator.
Old Jul 31, 2002 | 02:45 PM
acarnut's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by jp2002ls1:
</font>
If you pull the belt off the pump, you'd have to disconnect the pump from the rack. Typically, you leave the fluid in and route the hose from one side of the rack to the other side of the rack.
Since the pump is idle when you're driving in a straight line, the gain would be minimal - 3 to 5 hp? Be sure to sign up for the gym and those upper body workouts so you can park that thing.
A quick search found this:
http://www.woodwardsteering.com/powers3.htm#10e
What's the hurry?
DaveH
HectorM52
Jul 30, 2017 11:46 AM
linz
3rd Gen / L98 Engine Tech
Oct 22, 2015 07:59 AM
alphaauto
Jan 23, 2015 07:42 AM
ro2207
Dec 4, 2014 06:18 PM
