Anyone have a COMPLETE list of parts needed for a Heads/Cam swap?
Old Jul 12, 2003 | 12:42 AM
chesee48's Avatar
Just want to make sure that i get everything that i need all at once.
I'm talking about any and all gaskets, bolts, lubes, fluids anything and everything.
Just wanted to see if anyone complied a list when they did their swap. Most likely im going with the cmotorsports gasket set but other then that, i wont have anything else.
Thanks guys.
Old Jul 12, 2003 | 11:53 AM
trax's Avatar
Off the top of my head...
Gaskets: Heads, intake, timing cover, water pump, EGR
Seals: Opti, Water pump, Crank
Tools: Balancer puller, Fuel line disconnect tool, assorted sockets (including spark plug socket), breaker bar / air tools, valve spring compressor, torque wrench
Parts you might not have thought of until you pull them off: Timing kit
Head bolts (pref. ARP)
Header bolts (i.e. Stage 8 locking bolts)
Crank hub bolt (not necessary but nice to have)
Radiator hoses
Oil Filter
Fluids: Oil, coolant, and containers to hold the stuff you drain out.
Lubes / misc. goop: RTV, Thread sealer, blue lock-tite, anti-sieze compound, grease
That list should save you a few trips to AutoZone and PepBoys.
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
startingstock
Exhaust System
Dec 12, 2014 06:40 PM
ModdedNerd
Dec 10, 2014 08:42 PM
mjcent922
Jul 27, 2002 12:42 PM
