Planning some upgrades, need suggestions.
Old Jul 8, 2002 | 07:08 AM
BlackPariah's Avatar
Post Planning some upgrades, need suggestions.
Hey all, just for a little background my 95V6 was swapped for a 98LS1 block about 2 months ago. I have worn it in quite well, and everything feels great.
I am now looking ahead to mods. I already have a CIA (remember its a 95, no air box) installed, and Corsa exhaust. I was considering a heads, cam swap and work on the suspension a bit. The factory DeCarbons have been on for over 95k.
I am looking for suggestions on a mild cam (ok its don't have to be too mild!) for the car, I take it to the strip about once a month and besides that I run it at night when cruising (read: not a daily driver). I want some good lope to it, nothing too rough.
I have a local mechanic that did the swap for me, I am sure he will have suggestions about the heads. Does anyone here have some numbers that have worked well for them?
Also in the valvetrain. Would I gain much with new RR's and springs?
Suspension is another story. I took the car to about 130 a few weeks ago and it felt very loose, like I was floating on the ground.
I was thinking Koni SA's with new springs. Also SFC, LCAs, Pan-hard, Torque Arm. Not sure on brads for this stuff. Sonph has really good prices.
~Taylor
Old Jul 17, 2002 | 12:22 PM
ScLeCo's Avatar
Post
headers?? A-4, M-6?
IMO TR makes some of the best cams
just my o2
//BLACK 99 SS//M-6//T-Top//TR 224/224 .561/.561 112LSA//CNC Stage 2 Heads 2.08"Intake-1.60" Exhaust Valves//Volant Cold Air Induction//BBK 80mm Throttle Body//SLP Stage 1 Suspension Kit// Powerslut Rotors//Hawk Pads//Mosser 12 bolt-4.10 Gears//SPEC Stage 3 Clutch//ASP Underdrive Pulley//Lingenfelter Aluminum Driveshaft//BMR Sway Bars-Lower Controll Arms-Panhard Rod-Track Pak-Strut Tower Brace//Taylor Wires-NGK plugs//HPP 3-160 Stat//Skip Shift Eliminator//B&M Ripper Shifter//SLP LT Headers-SLP ORY No Cats//Borla Cat Back//Dynomax Bullit//ECT...
95maroboi
Jun 7, 2015 12:18 PM
blkWidow
May 3, 2015 08:42 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
92ragtop
Dec 27, 2014 01:56 PM
