Questions about a 383 stroker?
Old Jul 13, 2002 | 08:34 PM
drewski_SS's Avatar
Question Questions about a 383 stroker?
i want to convert my stock ls1 motor to a 383 stroker, if i were to do this would it be like a rebuilt engine with 0 miles on it. Also would this engine be more durable then a regular 350 ls1 engine? thanks for all replies and info
Old Jul 14, 2002 | 04:55 PM
Capn Pete's Avatar
Post
Would it be like a "new" engine with "0" miles on it? Yes. Would it be "as durable" as the original 350? Not quite.
When you're building the new motor, you would have to (or you should) replace things like all main bearings and rod bearings, timing chain, cam bearings, etc., and since you'd have to get new pistons (designed for use in a stroker motor), you would have to replace the rings as well, so essentially, the motor is brand new.
In terms of durability though, with a longer stroke comes increased load on the crank and the bottom end of the block, so for long-term durability, it may wear a little sooner than an original 350, but it's not going to be that bad that you have to be afraid to drive the car --- I had a 383 in my '81 Z28, and I (at 17-18 years old) abused the hell out of that car, and yet it ran mint, so it's not like you have to worry constantly, I just think that for a 383 compared to a 350, the 350 may outlast the 383 by a little bit.
If I were you, I would definitely go for it. I'm actually considering doing the same ONE DAY, once my motor has lots of miles on it, and once I can afford to (cause right now I'm f'ing broke!!!! ).
Let us all know what you decide to do and how it turns out.
2002 Z28 - A4, 2.73's, Blk/blk, leather, T-tops, sport appearance package - just bought on June 26, 2002! - Pics
1981 Z28 - 383, TH350 trans., 3.42 posi - sold August, 2000 - Pics
1973 Camaro - Dad's & my project in the works - to be built: 355 Chevy, 11.5:1 pop-ups, "camel hump" heads (w/2.02 valves), solid cam, 4-speed.....it should be quick! - No Pics yet.
Old Jul 15, 2002 | 07:55 AM
drewski_SS's Avatar
Post
i think i will. thanks for ur help, i really apperciate it.
Old Jul 15, 2002 | 09:46 PM
94z'sson's Avatar
Thumbs up
slp put a 382 stroker in a stock 2000 a4 w/ a good cam and it put it into the 10's its a good choice.
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Killer94z
Jan 13, 2015 12:06 PM
spearous
Jan 12, 2015 11:03 AM
