Rear End Oil
Old Jul 2, 2003 | 10:25 PM
zoomjrl's Avatar
Rear End Oil
I had to do some rear end work a week or so ago, and I had to replace the rear end gear oil/lube. At the time, all that was available to me was Quaker State 80W-90 GL-5 Synthetic for Limited Slip Rear Ends. I went to the dearlership today and they wanted $27 per quart of the GM stuff that the manual recomends. Mobile 1 was only $7 per quart. Do I really have to put the GM oil in there, and does anybody know why GM oil is so expensive?
Old Jul 2, 2003 | 10:35 PM
crazyswede1027's Avatar
I am no expert on this but I think you can use any gear lube you want as long as it meets the viscosity and weight ratings the manual calls for. I do believe that gm has an additive you have to put into the fluid because of the limited slip diff. May want to check with the service department for a definate answer.
Old Jul 2, 2003 | 11:00 PM
Ferocity02's Avatar
I got Red Line 75w-90 for my rear end. It was about $8 for a quart and already has the additive
AL SS590 M6's Avatar
Moderator
Re: Rear End Oil
What you put in there shold be just fine and beings that it says for LS differentials you shouldn't even have to add the Gm posi additive.
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Chet1185
Feb 4, 2015 09:51 PM
jcamaro95lt1
Jan 24, 2015 08:21 AM
nodnarb481
Middle Atlantic
Jan 1, 2015 11:43 PM
