)-Ringed Block
Old Jun 30, 2003 | 12:35 PM
LJ93Z28GM's Avatar
O-Ringed Block
I purchased a 80-85 truck block a year or so ago that is machined and ready to go but my question is, it has been 0-ringed. When i purchase heads do i need to have the heads machined for a receiver groove or can you run a head without any machining to it.
Anyone have possible gasket options as well.
Old Jun 30, 2003 | 07:41 PM
teamsleep13's Avatar
Yes you can use a normal head gasket and not machine your heads. I think fel pro makes a gasket that acutaly has an o ring kinda thing in it and works well when ur block has o ring groove.
Hunter
Old Jun 30, 2003 | 09:35 PM
LJ93Z28GM's Avatar
I will have to look into that. Do you typically or normally machine the heads as well or is it just the block.
Do you have a part number for that gasket ??
Old Jul 1, 2003 | 12:35 AM
Well when using an o ring you machine the block and head and then use a gasket with the o ring.
If you use a gasket with an o ring groove and no o ring it still helps, as the gasket will deform into the groove and help seal the cylinder better.
For the Fel Pro gasket, I don't have the part number, but if you go with just a copper head gasket with the block grooved, you should be fine, and you'll have better sealing cylinders.
Hunter
GREEN3112
Feb 10, 2019 09:19 PM
9t4lt4z28
Oct 2, 2015 10:28 AM
Z Power
Sep 19, 2015 11:19 PM
DelSoto
Sep 19, 2015 05:31 AM
heus
Sep 8, 2015 12:01 PM
