coolant swap additives?
Old Jun 30, 2003 | 11:21 AM
scoobysnax83's Avatar
Is there any additive for radiators and cooling systems to flush them? Kinda like motor flush for oil. I'm flushing the bad boy out and want to know. Thanks...
Old Jun 30, 2003 | 11:33 AM
TobyZ28's Avatar
Re: coolant swap additives?
I know there theres somethign at the dealership they use... this is from a local dealer:
Enginewity Cooling System Cleaning Process
Dissolves the calcium, polymerized coolant and limescale buildup in your radiator and engine and helps to maintain correct operating temperatures.
Helps extend the life of your cooling system.
Improves overall dependability
Don't know what it is, but it apparently does something!
Old Jun 30, 2003 | 11:35 AM
now is this something that we can buy, or is it something that the dealership uses when you take it to them to take it up the a$$?
Old Jun 30, 2003 | 12:47 PM
Terran2k's Avatar
hmm i have a bottle of prestone super flush, which supposed to get rid of rust and all sorts of deposits. but the reason i havent used it yet is b/c I dont know how safe it is, maybe some1 has used it before and can give some insight, so i may flush my rad already as well =
Old Jun 30, 2003 | 01:26 PM
notstock4long's Avatar
I read somewhere that the dealership has some stuff you should use when you change the coolant. There is a pt# for it, and they reccomend using two bottles of it every time or something.
blac94Z
Feb 15, 2021 09:43 PM
Naanz
V6 Tech
Feb 14, 2016 11:11 AM
sberry3827
Apr 10, 2015 08:40 AM
sberry3827
Apr 9, 2015 04:27 PM
