coolant swap additives?
Is there any additive for radiators and cooling systems to flush them? Kinda like motor flush for oil. I'm flushing the bad boy out and want to know. Thanks...
Re: coolant swap additives?
Originally posted by scoobysnax83 Is there any additive for radiators and cooling systems to flush them? Kinda like motor flush for oil. I'm flushing the bad boy out and want to know. Thanks... Enginewity Cooling System Cleaning Process Dissolves the calcium, polymerized coolant and limescale buildup in your radiator and engine and helps to maintain correct operating temperatures. Helps extend the life of your cooling system. Improves overall dependability Don't know what it is, but it apparently does something! |
now is this something that we can buy, or is it something that the dealership uses when you take it to them to take it up the a$$?
hmm i have a bottle of prestone super flush, which supposed to get rid of rust and all sorts of deposits. but the reason i havent used it yet is b/c I dont know how safe it is, maybe some1 has used it before and can give some insight, so i may flush my rad already as well =:)
I read somewhere that the dealership has some stuff you should use when you change the coolant. There is a pt# for it, and they reccomend using two bottles of it every time or something.
