Mod Suggestions
Old Jun 23, 2002 | 02:07 PM
KevinAce's Avatar
Post Mod Suggestions
Hey,
I'm about to be a proud member of the LS1 community; about to pick up a '00 Trans Am with Ram Air. I'm looking at mods ahead of time. Here's what I'm looking to get so far:
- LS1 Motorsports Direct-Flo intake lid
- Granatelli calibrated mass airflow sensor
- Ported MAF ends
- Granatelli High Flow Calibrated MAF
- MAF translator
- 58mm throttle body
- Flowmaster (80 series probably?) dual exhaust
I'm basically an idiot as far as mods go, are any of these repetitive, or wasteful on the 00 Ram Air equipt LS1 engine? Any suggestions, or further mods would be much appreciated.
Thanks,
Kevin
Old Jun 23, 2002 | 03:35 PM
VetteThreat's Avatar
Post
You definately want to get the lid as one of your're first mods. It's probably one of the best for the money. As for the MAF and MAF related mods, most guys on this message board say they felt little or no difference at all from the MAF. It doesn't seem to matter what brand they have, most say it wasn't worth it. Also I have a Borla full cat exhaust and this was by far the mod that I felt the most difference from. Im not sure if the Trans Am has a tuned exhaust like the SS does but if it does then exhaust probably isnt worth it either.
Black 2001 Z28 Auto
Mods: Borla full cat exhaust, SLP ram air, SLP 160 Thermostat, SLP smooth bellows, MTI lid
Best 1/4: 13.469 @ 105
Old Jun 23, 2002 | 03:37 PM
Talking
Oh yeah by the way welcome to the LS1 community!!!!!
Old Jun 24, 2002 | 01:36 AM
KevinAce's Avatar
Post
Any other comments on this? What are the typical mods people get with a fairly new WS6 (it's the same as the 2001 year, correct)?
Old Jun 24, 2002 | 02:16 AM
redz_02's Avatar
Post
Sounds good, but if you are getting a Grenetelli why would you need ported mass air flow ends, they already come that way. Plus it doesn't really add much to a stock car without internal engine work. I would hold up on the mass air meter and get some gears, to answer what size i need to know if it is an automatic or a manual. The lid and exhaust are a good first. I would look into a catback instead of just a muffler. Borla, corsa, B&B, although expensive make excellent 3 inch stainless steal catbacks. Or you could just through a cutout onto the WS6 exhaust that ramair has.
'02 Red Z28, ebony leather, M6, T-tops, Trac. cont., hurst shifter
-Borla (the expensive cut-out)
-Wisperlid W/K&N
-FRA
-Cags eliminator
-Strange 4.10's
-G2 Rear Girdle
-Valv. Synthetic 10W-30
-Redline gear oil
-Fat hurst shift ****
-Lead foot
Soon to be:
Alpine Screen, Orion xtr 800.4, xtr 900.2, Kicker 12L7 in a milhouse, Focal polykev K2's.
Old Jun 24, 2002 | 04:06 AM
KevinAce's Avatar
Post
Hey,
Excuse the ignorance, but what in the hell is a cutout for exhaust? It should explain itself...is it basically just putting a whole in the pipe? Also, what's the difference between a catback, and just mufflers? Catback is basically the entire system, allowing more overall air flow?
Kevin
Old Jun 24, 2002 | 06:11 AM
EviLBoX's Avatar
Post
Here's a good cutout explanation:
http://installuniversity.com/install...xplanation.htm
1997 Bright Red Z28
A4, 3.23's, K&N FIPK, FLP Headers, Flowmaster, Cutout
My Z28
Old Jun 24, 2002 | 07:59 AM
Blue By You's Avatar
Post
As for Mods for your car. It all depends on what you are going to do with your car. Drag race, daily driver, show car?
As for me mine is a daily driver with occasional time at the track to vent(LEGALLY).
I just installed a Hotchkis Strut brack (this goes over the motor) and it made a difference in the handling of the car. I also just installed a set of Kenny Brown Double Diamond SFC's (sub frame connectors). Big difference there as well. With the SFC my exhaust is still lower than the SFC. Plenty of ground clearance. My next step is to lower the car. It's just a thought. I hope this helps. See my signature for my MODS. I also have a Corsa Exhaust. I love it. But it's expensive. I guess you get what you pay for.
Carrie
2000 Z28 LS1, Navy Blue Metallic, T-tops, Eagle GSC, 6 Speed Hurst Shifter, 12 Disk CD Changer, Carbon Fiber Letters, Whisper Air Lid, K&N Filter,MBA Aluminum Grill Inserts, MBA Aluminum Pedals, MBA Blue MAF Ends, Corsa Exhaust, Power Slot rotors, Hawk Pads, Kenny Brown Sub Frame Connectors, Hotchkis strut bar Polished, More to come?
Old Jun 24, 2002 | 04:29 PM
KevinAce's Avatar
Post
Hey,
That's what I figured it was; are their certan limits to how much air a cutout can flow, or are they all legal / illegal, or what? Obviously, it's not too enviornment-friendly; just wondering what the legalities of these are.
Kevin
Old Jun 24, 2002 | 06:51 PM
2001CamaroGuy's Avatar
Post
I have a 01 Z28. Looking over your list of mods, they are pretty good. Suggestions:
As someone else said, the Granatelli has ported ends.
If you are getting a MAFT, then I would suggest you get the SLP 85 mm MAF (larger ID will flow more than the Granatelli). The MAFT will allow you to calibrate it yourself.
The larger TB for an LS1 is 80 mm (BBK). I just installed one this weekend. LOVE IT!!! The first time I drove it my friend was in the car with me and the car snapped both of our necks HARD!
DON'T get the flowmaster. I have it and it’s coming off as soon as my Loudmouth comes in. It really cut some HP out of the car. Sounds good but I think the Loudmouth will sound just as good and will give me more HP.
If I were doing my car over, this is what I would do:
- LS1 Motorsports Direct-Flow intake lid
- SLP 85 MM MAF
- MAF translator
- 80mm BBK throttle body
- Loudmouth (Dynomouth.... if you don't mind moding the stock exhaust and save $$$)
- LT headers
- SLP bolt on subframes
- G2 springs (going to change to their coil overs when I have the money...)
- Hotchkis Strut Tower brace
(the suspention stuff I have and it has worked really good)
[This message has been edited by 2001CamaroGuy (edited June 24, 2002).]
Old Jun 24, 2002 | 10:24 PM
Post
Not to down grade SLP but I wouldn't get them due to the clearance issue. Plus they are a lot heaver than the ones I have on my car. I had checked them out while I was at SLP day and can't figure out why there is a huge lip on them. Again it's just my .02. Sorry if this nakes you think twice about this but it might be for the good.
Carrie
LETZRIDE
Outside of United States
Jul 9, 2015 07:17 AM
1775.Z28
N2O Tech
Apr 7, 2015 04:09 PM
IgorT.455/406
Mar 12, 2015 03:39 AM
Brad122470
Aug 2, 2002 08:55 AM
