fuel injector o-rings
Old Jun 26, 2003 | 09:50 PM
slverbullet's Avatar
okay, i need to change out my o-rings on my injectors. i can hear i got a leak in one of them. ive never had the oportunity to do this before so if anyone has any advice, please lend some. like how to make sure there is no pressure on them and how to bleed it off if there is. do i need any tools to take them off or can i just pop them out. any other precautions? thanks guys.
dave
Old Jun 26, 2003 | 09:59 PM
thad's Avatar
open the gas cap to relieve the pressure. You might need the gm fuel line release tools...They are $10 at sears. the just follow the first few instructions on the intake manifold gasket write up.
http://www.projecttransam.com/projects2.asp
When the injectors come out, you'll see the o-rings...it's pretty easy. 30 minutes, unless you take your time looking over the injectors.
Old Jun 26, 2003 | 10:20 PM
96z's Avatar
96z
When you take off the gas cap you dont relieve any pressure at all. To do it the right way you must relieve the pressure at the schrader valve on the fuel rails. It looks like a tire valve. Just push down on the valve and the gas will come out....have some rags handy.
Then unbolt the 4 fuel rail bolts and give it a tug, it maybe on there good, keep on pulling it will come. From there just pull out the injectors and replace the o rings.
You dont have to but you can also disconnect the fuel lines from the rail itself by using a fuel rail disconnect tool. Its just a little plastic disk....you dont have to but some like too. If you dont want to use it just flip the rails around with the lines still attached.
whoo...
Old Jun 26, 2003 | 10:41 PM
pennys58's Avatar
are the "o" rings the little rubber things at the end of the injectors? Do the just pull off? WHere can you find them...do you have to go to gm or can you go to autozone or oreileys?
JOHN
Old Jun 26, 2003 | 11:14 PM
96z's Avatar
96z
Yeah the are rubber rings. There is one at the top of the injector and one towards the bottom. I know NAPA for sure has them...any normal autostore should carry them...
Old Jun 27, 2003 | 03:34 PM
hey, seeing as how there are two o-rings on the injectors, which ones should i replace if i'm experiencing a leak? both of them?
Old Jun 27, 2003 | 04:08 PM
Eddie95Z28's Avatar
I would say that depends on which one is leaking.
Old Jun 27, 2003 | 04:30 PM
well, i'm not really too sure. so i'm just gonna replace them all and clean them all up. if i should replace them both, are they all the same size. thanks.
dave
Old Jun 27, 2003 | 05:26 PM
dave
I have not messed with mine, but I'm thinking they are different.
This kit will get you all the rings:
1994-1997 fuel injector o-ring seal kit
ACDelco #217-1379
GM p/n 17113544
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
