How to adjust Throttle cable
Old Jun 16, 2002 | 03:33 AM
Team Geno's Avatar
Exclamation How to adjust Throttle cable
I just bought the BBK TB, and I'm having problems with the Trottle cable with this TB.
Cesar
98 SS droptop A4 3.23
lightly modded
70 RS 350
under restoration
93 V6 (Sold)
FIPK, Nuology wires, Pullies, 3 inch Cat with flows and Loudmouth tips, and a bunch of suspension mods.
Old Jun 16, 2002 | 04:22 PM
Team Geno's Avatar
Question
TTT
Old Jun 16, 2002 | 04:48 PM
Camaro ChriSS's Avatar
Post
Is the cable too loose, or what is the problem exactly? If too loose, there coil in a small black clip (cynlinder box) than be used to adjust the tension (though it may not exist on the 98 model).
There have been some problems with BBK TBs sticking terribly - the blade won't open properly.
2000 Pewter SS #C161
SLP Dual-Dual, Bilstein suspension, Eibachs, 21mm/35mm swaybars, GMAF
SLP CAI w/lower plate, !EGR, Direct-Flo, SLP STB, Ported TB, ASP Crank pulley
SLP/AAM Differential cover, SLP 2600, Powershot, MSD wires, NGK's,
BMR Boxed LCAs, BMR PHB, G2 DSL, Heavy Lead Foot...
http://community.webshots.com/user/murlynd
Old Jun 17, 2002 | 01:33 AM
Team Geno's Avatar
Question
The BBK seems fine, but when they made it, they didn't think about the spacer which was included with the TB. The spacer moved the TB about 1/2 inch foward, and now the throttle cable can't hit the bump stop(screw). The cable is not too short for the TB. The strange thing is that I can make it hit the bump stop, and fully close the TB. Now if I can only adjust it to do that when I hit the gas pedal.
Cesar
lightly modded
70 RS 350
under restoration
93 V6 (Sold)
Old Jun 17, 2002 | 01:24 PM
Post
I'm trying to picture it... is it not closing properly (staying part open) - is that it? You should be able to lengthen the throttle cable.
Old Jun 18, 2002 | 03:28 AM
Team Geno's Avatar
Thumbs up
Thanks for your replies Cris, but I got. The TB is working fine now. I played with the spring in the throttle cable.
Cesar
lightly modded
70 RS 350
under restoration
93 V6 (Sold)
Fastbird93
Apr 9, 2016 07:01 PM
jimmybandana
May 11, 2015 11:41 AM
edman
Jan 25, 2015 02:41 PM
DETROIT_AREA_00_SS
Aug 12, 2002 11:32 AM
