discontinuation of SLP underdrive crank damper/pulley
Old Jun 11, 2002 | 09:38 PM
sicvic's Avatar
Red face discontinuation of SLP underdrive crank damper/pulley
I bought this thing a year ago and I'm finally getting around to putting it on, when I look in SLP's newest catalog and find that they've discontinued it. What gives? Were there problems with it? I love my motor and don't want to wreck it. Does anyone have the instructions they can fax me? How about belt recommendations?
Old Jun 13, 2002 | 05:42 PM
Sparky's Avatar
Post
Some pullies would cause false KR. Different from car to car.
Mark
Old Jun 14, 2002 | 03:38 PM
Camaro ChriSS's Avatar
Post
There were a lot of problems with the SLP crank pulleys and they stopped selling them about a year ago. Failure rate (that is, unsatisfacotry performance) was around 50%.
I initially had one on my SS, installed by SLP while being built. I didn't have false KR like some guys, but the pulley caused slipping of my belt from 4500-5500 rpm, and a power loss of 40 rwhp in that range. Completely unsatisfacory.
They refunded my money and I subsequently had an ASP put on. I would strongly recommend sending the slp unit (even if it is a year old) and purchasing an ASP.
SLP products are good. Just not the pulley. And they know that now.
2000 Pewter SS #C161
SLP Dual-Dual, Bilstein suspension, Eibachs, 21mm/35mm swaybars, GMAF
SLP CAI w/lower plate, !EGR, Direct-Flo, SLP STB, Ported TB, ASP Crank pulley
SLP/AAM Differential cover, SLP 2600, Powershot, MSD wires, NGK's,
BMR Boxed LCAs, BMR PHB, G2 DSL, Heavy Lead Foot...
http://community.webshots.com/user/murlynd
Old Jun 14, 2002 | 08:04 PM
sicvic's Avatar
Post
Thanks for the replies. Stupid question: What's a false KR? Code reading? Also, ChriSS, you said you like the ASP pulley. Did you dyno the car with and without it? What difference did it make in rwhp and/or run times? Any problems cranking tunes at an idle? That was a constant problem with my '89 Saleen (finally got smart and went GM in '94).
Old Jun 15, 2002 | 12:36 AM
Post
<font face="Verdana, Arial" size="2">Originally posted by sicvic:
Thanks for the replies. Stupid question: What's a false KR? Code reading? Also, ChriSS, you said you like the ASP pulley. Did you dyno the car with and without it? What difference did it make in rwhp and/or run times? Any problems cranking tunes at an idle? That was a constant problem with my '89 Saleen (finally got smart and went GM in '94).</font>
The LS1 has a sensitive sensor called a "knock" sensor, designed to detect detonation (ie form poor gas) and other vibrations harmful to your engine (over the long run) - in response, when knock is detected, the sensor and PCM will 'retard' timing to try to minimize damage to your engine (which kills horsepower too - KR is Knock Retard). Sometimes it gets fooled though by simple vibrations (like headers banging against the floorboards, etc...) and reacts as if there is a serious detonation problem (killing hp) - when it gets fooled like that, it is called false knock.
Unfortunately, I haven't done a dyno or track run since the swap, but the engine accelerates much better - no big stutter at 4500 rpm. Never a problem with charging or accessories with the crank pulley on the A4.
HarleyZ28
Oct 5, 2015 06:23 AM
QuickSilver02
Apr 7, 2015 11:12 AM
racecarz28
Mar 30, 2015 09:55 PM
Rde Bandit
Mar 21, 2015 10:17 PM
