Testing for a bad opti
Old Jun 22, 2003 | 06:46 PM
z2894convertible's Avatar
Question Testing for a bad opti
Is there any way I can check my opti to see if it is bad? I am haveing problems with my car and I think it is the opti, but I would hate to replace it if it isnt bad. Thanks for any help.
Old Jun 22, 2003 | 07:24 PM
RRios8191's Avatar
Help!!
I would like to know too. Anybody with ideas??
Old Jun 22, 2003 | 07:54 PM
Camaro_Maniac63's Avatar
If you have no spark at the plug wires, then your opti-spark is no good. This is the only way I can think of checking if it is good or bad.
Old Jun 22, 2003 | 08:21 PM
The opti can still be bad even if you are getting spark because if it is bad you may not get enough spark
Old Jun 22, 2003 | 10:11 PM
kostya_f's Avatar
The optical part sends a high resolution and a low resolutoin signal. If you connect an oscilloscope to each and see missing steps(the voltage changes as each hole passes the sensor) then your opti is bad.
Old Jun 22, 2003 | 10:22 PM
NeoSNK's Avatar
I would say pull a wire and hold a spark plug against the engine. You should have a nice blue spark.
ad356
Apr 11, 2015 10:30 PM
Injuneer
Dec 15, 2014 09:36 AM
naaz90
Jul 27, 2002 08:22 AM
