What is that sensor on yout elbow do
Old Jun 20, 2003 | 01:06 PM
5H9D0W's Avatar
Question What is that sensor on yout elbow do
The sensor that plugs into the side of your intake elbow on the passenger side.What does it do,and where does it lead. Mike
Old Jun 20, 2003 | 01:07 PM
SSkindog's Avatar
Re: What is that sensor on yout elbow do
I think it is the Inlet Air Temperature sensor
Old Jun 20, 2003 | 01:09 PM
Buttercup's Avatar
Re: Re: What is that sensor on yout elbow do
You are correct
Old Jun 20, 2003 | 01:17 PM
5H9D0W's Avatar
Is it a problem if you don't have one.Where does it route from.
Old Jun 20, 2003 | 01:24 PM
5H9D0W's Avatar
ttt
Old Jun 20, 2003 | 01:27 PM
Buttercup's Avatar
Generally speaking the PCM likes to have all its sensors It uses the data for things such as determing spark advance. It simply plugs into a wire harness which leads back to the PCM.
Some people relocate it closer to the air filter (or use the integrated IAT on some MAF sensors), is this what happened?
Old Jun 20, 2003 | 01:29 PM
5H9D0W's Avatar
Please specify about the,integrated IAT on some MAF sensors,I bought the car w/ a cai,and a granfitelli MAF.
Old Jun 20, 2003 | 01:32 PM
Buttercup's Avatar
Like the ZO6 MAF. If that isn't being used than check your induction closer to the filter. Many people relocate the IAT further away from the engine in order to get colder readings to get a bit more spark advance.
Aug 24, 2015 06:41 AM
350350
14
Aug 11, 2015 12:03 PM
zajones
Jul 30, 2015 02:18 PM
colts0455
Jul 24, 2015 04:51 PM
Noct
Jul 14, 2015 01:18 AM
