T-trim boost quicker?
Old Jun 20, 2003 | 04:40 AM
Highlander's Avatar
Does the T-trim boost quicker than the S-trim?
Old Jun 20, 2003 | 06:57 AM
MEAN LT1's Avatar
Re: T-trim boost quicker?
All depends on how you have the pullies setup.
Old Jun 20, 2003 | 07:26 AM
Highlander's Avatar
Whatever it takes for a maximum boost of 10 psi on each
Old Jun 20, 2003 | 10:16 AM
JordonMusser's Avatar
West South Central Moderator / Special Guest
well, the T-trim will build less boost at low RPM assuming pullied the same.. (somebody correct me if im wrong)
Old Jun 20, 2003 | 10:44 AM
Highlander's Avatar
Not necesarilly pullied the same... just that both will reach the same max boost.
Old Jun 21, 2003 | 06:03 PM
engineermike's Avatar
According to the compressor maps on Vortech's website:
http://www.vortechsuperchargers.com/...-trim_map.html
The orange lines show the pressure ratio (boost) versus air flow for different compressor speeds. They are the same for the S versus the T trim. However, at just about every point on the curve, the T-trim has a higher adiabatic efficiency (lower discharge temps).
Mike
RUENUF
Mar 13, 2016 03:37 PM
Mikes 1994 z28
Oct 10, 2015 07:55 AM
Daluchman1974
Sep 11, 2015 06:12 AM
96SilverRam
Sep 7, 2015 10:51 PM
Henson071
Aug 4, 2015 09:32 AM
