V8 exhaust on a V6
Old Jun 19, 2003 | 03:26 AM
jetman624's Avatar
V8 exhaust on a V6
I has wondering, could I put a cat-back thats for 93-95 LT1 on my 94 3.4? If so, do I have to do anything special?
thanks for your help
Old Jun 19, 2003 | 10:13 AM
ImportKILLER's Avatar
Use the search feature...
Old Jun 19, 2003 | 11:16 AM
nothingeined's Avatar
You can use it no problem. Should be a perfect fit.
Old Jun 19, 2003 | 08:38 PM
jetman624's Avatar
Should Fit?
Should Fit? Has any one actually done it. I hate to spend 300 bucks and order on and it not fit.
Old Jun 19, 2003 | 10:49 PM
300 bucks?!? That is a bit much. Have you searched on the for sale section here? I got mine for 35 around me locally. I have one on my car and it went on seamlessly. Mine is a 2000 and it came off a 1999 Z28 and it fit everything well. But go ahead and do a search.
Old Jun 20, 2003 | 12:59 AM
fbird95's Avatar
Definatly do a search in V6, this topic has come up a few times. If you want search for my posts in V6 i have given the run down on V8 rear sections on V8 cars many times.
As for the cat back off a LT1 car, The only minor trouble you will face is that you will need a shop to make the connection to the cat unless you a welder or know someone who is. Honestly, you dont need that wide of a intermediate pipe on a 6 cyl. It may actually cost you power. I recomend just the rear section you can get them from slp for 119.99 shipped or the cat back as you mentioned for 99.99 plus shipping from www.hawksthirdgenparts.com . If you look around you can them even cheaper, but watch out for ebay cause many times the morrons sho ship them cut them all up making the install a pain in the ***.
Old Jun 20, 2003 | 02:13 AM
camaro6's Avatar
Yeah, it'll work. I put a 2000 Trans Am exhaust on my 94 camaro. Here's a picture of it.
Old Jun 20, 2003 | 03:56 AM
jetman624's Avatar
Its not that I want the larger I pipe, its that I like the sound of the Hooker cat-back and they only make them for the V 8's.
Old Jun 20, 2003 | 03:23 PM
Satellite98's Avatar
I thought you were talking about a take-off t/a exhaust. In that case $300 for a catback would be reasonable, unless-maybe-it is used.
Old Jun 20, 2003 | 05:07 PM
WhoBetter?'s Avatar
don't except your car to sound like an LT1 just because your putting on an LT1 exhaust. I never thought it was a good idea to put an exhaust designed for a v8 on a v6 car, I think you would b better off getting an exhaust designed for your engine, i think pace setter has a decent one, do a seach for it.
Old Jun 20, 2003 | 10:08 PM
jetman624's Avatar
Obviously it will not sound like a V8, but every muffler is shaped and sized different and gives the exhaust note a different sound. I have heard a hooker cat-back on both and I thought it sounded rather good. All though now I am considering having one made and using spin tech mufflers, they are supposedly one of the best. According to Doug's headers, former owner of Thorrley headers.
Old Jun 21, 2003 | 01:58 AM
fbird95's Avatar
Well if you like the hooker sound, pick up a hooker aerochamber muffler from jeggs or summit, they run about 70 bucks and just have a shop weld it in there with or with out an additonal tail pipe. This will wind up costing you less in the end, and will sound a little better, while still maintaining a decent amount of back pressure for your engine.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
May 21, 2015 01:04 PM
Pyrocam 95'
Exhaust System
May 20, 2015 12:51 PM
May 15, 2015 10:43 AM
jasonduaine
Exhaust System
Mar 20, 2015 09:00 AM
