noise after welding in the frame ties...what is it???
Old Jun 18, 2003 | 07:58 AM
asianice25's Avatar
Angry noise after welding in the frame ties...what is it???
I put on my competition engineering subframe connectors on this weekend after letting them collect dust for about a year. We welded them in and painted them nice and good. now when i go over a decent size bumb the right rear makes this huge banging noise. sounds like a shock just broke through the upper mount or soemthing. any ideas as to what it might be? When i put them on i turned up my kyb agx's up to 7 on the back, and its really stiff now. could that be it? im going to lower the shocks down to 4 this weekend to see what happens, but its really pi$$ing me off. I put these on the stiffin and quiet, not to make more annoying noises...any help would be appreciated. thanks.
Old Jun 19, 2003 | 04:05 PM
alex94z's Avatar
Did you weld the rear mounting point? If not, that could be the cause.
Old Jun 19, 2003 | 04:58 PM
Ken S's Avatar
did you tighten your LCA bolts enough?
Old Jun 19, 2003 | 09:45 PM
rotwiler's Avatar
I put some bolt on SFC's and noticed on certain hard jolts in road I will hear a noise like you are describing near the rear of the passenger side door. checked bolts and they are all tight on the SFC's. thought it was from car trying to flex.
Old Jun 20, 2003 | 07:22 AM
asianice25's Avatar
Unhappy
Im going to make sure everythinng is tight again this weekend. Then im going to grease the bushings. The rear is welded too. I just raised the car, so im going to see what happens. Thanks.
football4life
Oct 4, 2015 07:48 AM
autoxr166
Sep 25, 2015 04:21 PM
Daluchman1974
Sep 11, 2015 06:12 AM
rideordie
Sep 7, 2015 08:22 AM
4586
Aug 18, 2015 07:08 AM
