Is Master Cylinder Mated To Slave Cylinder
Hola F-Buds,
Another question for you T56 Guru's.
Was curious if the two cylinders (Master & Slave) are actually mated together(with steel braided lines,) or are totally seperate all in itself.
I have bought them both, however when I lined them up, they look exactly the same. I'm afraid of either; I might have purchased the Master Cylinder twice, or bought them both twice. Comprende? ; )
If you have pics, that would be exellent.
Gracias.
Ruben F.
Gracias.
Ruben F.
Generally sold as a complete assembly, including the reservoir, master cylinder a couple feet of hose and the slave. The master has an angled mounting plate, at about 45-degrees to the cylinder body, so it can stick through the firewall. It is held there by a u-bolt that sticks through the firewall also. The mounting flange on the slave is perpendicular to the body, and mounts to the support cup that goes on the side of the bell housing, with two bolts holes.
Check "shoebox"s site... he has "blowup" pictures of just about everything.
Have Mercy.....!!!
I salute you Injuneer, I DEFINATELY realize that I have purchased two complete assemblies. I hope you don't mind me "stealing" your reply and pasting it to my notes, I'll give you credit when I have enough for a novel. ; P
I appreciate your time.
Ruben F.
P.s. I guess that was just too easy of a ? for ya. lol
I salute you Injuneer, I DEFINATELY realize that I have purchased two complete assemblies. I hope you don't mind me "stealing" your reply and pasting it to my notes, I'll give you credit when I have enough for a novel. ; PI appreciate your time.
Ruben F.
jackpawt883
Sep 10, 2015 08:53 PM
