Solid roller guys
Old Jun 17, 2003 | 10:08 AM
KCFormula's Avatar
Solid roller guys
I have pretty much decided to do a 355 solid roller. I was wondering what valvetrain parts I would need to do this to a stock LT1? Would I need adj. rocker arms? Machine work to heads? Machine work to bottom end?
I want something that has some low end but pulls hard up top. I even had the idea of running 18* heads with a solid roller. Anyone have comments?
Old Jun 17, 2003 | 10:15 AM
FuryZ28's Avatar
You're crazy, man!! Don't do it!!! Just playin'...bump for info.
Old Jun 17, 2003 | 11:31 AM
twells's Avatar
joe,
all you need to change is your entire valvetrain. i don't think you have to do anywork to the bottom end or the heads.
obivously you need a solid roller cam, the proper lifters, i am almost positive that you're going to need hardend pushrods, rr's ( i would go with non-sa and guideplates) good springs. i would get a cloyes dr timing chain and electric wp. that's all i can think of for now!
later
Old Jun 17, 2003 | 02:55 PM
mastrdrver's Avatar
Hey Joe tired of getting out ran by those LS1s.
Old Jun 17, 2003 | 05:30 PM
redygo's Avatar
youll also have to disable your knock sensors
Old Jun 17, 2003 | 05:32 PM
Camaro37's Avatar
I've been looking into doing this too, but looks to be too expensive for me though
From what I know you will basically need the whole valvetrain fixed up, like said above. Non self aligning rockers, 7/16 studs, hardened pushrods, guideplates, valvesprings, lifters, cam etc. Also you will need to pull the heads/get new heads to get them machined for the larger valvesprings that you will need for the SR cam. Maybe disable the knock sensor, some say disable, some say don't, I guess its up to you.
Old Jun 17, 2003 | 07:55 PM
KCFormula's Avatar
I wonder if the '93 (desensitized knock sensor) will need to be deleted?
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmyname1
Feb 19, 2015 08:38 PM
95chwagon
Jan 13, 2015 09:19 PM
Red97LT1
Aug 7, 2002 05:45 PM
