Can I rebuild my starter or am I screwed?
Old Jun 16, 2003 | 09:26 PM
SneakyZ's Avatar
Exclamation Can I rebuild my starter or am I screwed?
Well, I must say that I've never seen this before. My car has been starting intermittently over that last year, but it always started after turning the key a few times. I was getting a click from the solenoid first, then it would start. Well, it finally refused to start. I went to pull the starter, and the friggin' solenoid is pushed OUT of the starter motor housing. The little ears on the solenoid case are worn off, and the spring inside the solenoid is pushing it out of the motor case. The rest of the starter looks good though, so I hate to drop the cash for a new one if I can fix this one. Are parts available? The solenoid works when it's pushed into the housing, but it won't stay because the tab is gone that holds it there. Can I buy a replacement solenoid, or is this one of those "non-serviceable" units like my repair manual says it is (which I don't believe). Anyone run into this before?
Old Jun 17, 2003 | 12:59 AM
Van5150's Avatar
I had my starter rebuilt this past winter. I brought it into the guy who does great work and great prices. He looks at me and says "Ut-oh, thats one of those starters that always has oil on/in them and they are expensive for the rebuild kits, $90". I was happy cause I saw how much replacement ones were going for. So it is rebuildable.
Old Jun 17, 2003 | 07:19 AM
SneakyZ's Avatar
Thanks Van. I didn't think it would cost $90 though. I'm going to look at it later this week. Right now it only looks like the solenoid needs replaced, so if I can find just the solenoid I should be ok. Any idea where I can find the 'noid?
Old Jun 17, 2003 | 07:57 AM
No one sells an OTC solenoid that I know of, but you might be able to get what you need at a repair shop (if they will sell it to you).
Old Jun 17, 2003 | 09:24 PM
SneakyZ's Avatar
That's my next step, but I don't know if I'll be able to just buy the solenoid or if I'll get stuck with the whole kit. Thanks for your help!
Old Jun 17, 2003 | 11:34 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
you can buy a solenoid, buts its not worth it. I did, and then the starter went out 6 months later.
Old Jun 17, 2003 | 11:53 PM
1994CamaroZ28's Avatar
not highjacking your thread or anything but if what you got doesnt pan out i got one off of my buddies 96 Z that worked fine when the car parked will sell it resonably.
Old Jun 18, 2003 | 07:17 AM
SneakyZ's Avatar
Thanks guys, I'll probably just rebuild the whole thing anyway.
I'll keep that used starter in mind too.
Old Jun 18, 2003 | 07:35 AM
CANTONRACER's Avatar
Doesn't the LT4 come with a different starter that is smaller, better??
Formula Steve
Sep 19, 2023 08:31 AM
Bxlt1
Sep 29, 2015 03:18 PM
Z Power
Sep 19, 2015 11:19 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
