View Poll Results: What should I go with
Stock waterpump with new seal and gears
100.00%
Electric WP with Cloyes timing chain
0%
Electric WP without Cloyes
0%
Voters: 2. You may not vote on this poll
I can't decide
Old Jun 13, 2003 | 09:12 PM
Rodrigues's Avatar
I can't decide
I can't decide what I should do with this oil leak and what I beleive to be the waterpump. I already tore the front end apart to replace the opti seal. The problem still persisted which makes me believe its at the WP seal. I have an XE grind with the stock timing assembly with new GM chain. I also have my original waterpump in there with 99k miles and a brand new opti. Im wondering if I should go electric and fix this waterpump seal for good because I have to remove the timing cover to get the seal out. My WP gear shaft had a lot of play in it as well. A new GM shaft is $38 that bolts to the block. Should I go electric with cloyes? Replace stock WP gear and fix the seal?
I would definetely do an electric WP if they were risk free, but I dont want my engine to overheat if it were to die on me. How reliable are the CSI pumps?
magman
Apr 15, 2016 03:08 AM
David Dempsey
Mar 12, 2016 12:42 AM
Bxlt1
Sep 29, 2015 03:18 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
