fuel injector clips
Old Jun 13, 2003 | 07:40 PM
MLTA96's Avatar
Question fuel injector clips
I just bought the bosch #30 fuel injectors and I can't get the clips to go on. the ring on the injector isn't all the way around. do i have to use clips?
Old Jun 13, 2003 | 07:50 PM
drewstealth's Avatar
I would. You don't want those things to move around. After some time they can wiggle loose and you could get fuel all over.
Old Jun 13, 2003 | 08:13 PM
madwolf's Avatar
You don't have to, but it's good for safety. You can use a dremel to make a full ring on the injectors. That's what I did on a set of LS1s...
Old Jun 13, 2003 | 09:24 PM
MLTA96's Avatar
thanks madwolf, i used the dremel and have just 2 left to install and finished. save the two for the morning. too dark out.
Old Jun 14, 2003 | 01:40 PM
MLTA96's Avatar
with the fuel rail bolts tightened i see the part above the o-rings. the injectors won't push down any further because of the fuel rail. what gives?
Old Dec 11, 2004 | 04:14 PM
TobyZ28's Avatar
Re: fuel injector clips
Same problem here - can anyone help?
Old Dec 11, 2004 | 04:16 PM
Loadre's Avatar
I assume you mean the lower part of the injector where it goes into the manifold? That's normal if you can see the top of the o-ring.
Old Dec 11, 2004 | 04:52 PM
TobyZ28's Avatar
I installed the stock clips in the upper groove of the injector, this kept the top of the injector from going too far into the fuel rail, and the o rings are now just a tad deeper and no longer visible...
AdsoYo
May 2, 2018 03:21 AM
daves91z28
3rd Gen / L98 Engine Tech
May 12, 2016 06:19 AM
MyfateZ28
Jun 19, 2015 03:42 AM
QuickSilver02
Apr 7, 2015 11:12 AM
Jul 4, 2005 05:00 PM
