Destroyed supercharger impeller blades
Old Jun 13, 2003 | 04:52 PM
Highlander's Avatar
Can someone post me what they think about this???
I am awfully worried about it..
http://czar.cnnet.upr.edu/~chris/impeller.JPG Big Pic
http://czar.cnnet.upr.edu/~chris/impellerb.JPG Smaller Pic
maybe this is the reason why its only pumping 10psi with a 6.66 crank and 2.75 blower pulley...
Not exactly sure how this happenned or when, but the car was running fine before I took it off... Any thing to worry about or to check?
Let me know
Old Jun 13, 2003 | 06:14 PM
texlurch's Avatar
Weird, that is on the inlet side of the blower, right? You never ran it without a air cleaner on it, did you?
Old Jun 13, 2003 | 06:34 PM
ru2slo_99's Avatar
Maybe the bypass valve wasn't working. That is crazy looking.
Old Jun 13, 2003 | 06:42 PM
Highlander's Avatar
What does that have to do with the bypass valve??
Anyways... I did ran it a few days without air cleaner.. but where brief necessary trips... Maybe that explains why I lost 2psi boost instead of 1/2 psi that I should have lost with the vortech aftercooler...
The MAF is up top so the Bypass valve is being vented to atmosphere...
Its a high quality pic so you can zoom it
Old Jun 13, 2003 | 07:04 PM
texlurch's Avatar
Dayum! I downloaded it to zoom in.. them things are munched. The way they are shaved, and all being the same, sure looks like some foreign matter got in there. There isn't any way a part of the intake could get sucked in there, by chance? I am not that familiar with the intake piping...
If the bypass valve wasn't working, and you were getting reverse boost, I would think it would show up on the backside of the impeller, not the front?
Either way, that needs replaced..
Old Jun 13, 2003 | 07:57 PM
94LT1_89TTA's Avatar
Yes, it's clear something was ingested and contacted the blades while they were at speed. The fact that the edges of the blades where they are next to the compressor housing are not really hurt pretty much rules out bearing play and impeller / housing contact as the culprit.
It's bad enough that the blower is damaged, but what's worse is all that shrapnel went through the motor....
Roger
Old Jun 13, 2003 | 08:47 PM
ru2slo_99's Avatar
I have read that if the bov is not working then when the throttle is slammed shut, damage can occur to compressor wheel. That is probly more true for turbo's then superchargers.
Old Jun 14, 2003 | 12:12 AM
Highlander's Avatar
Motor seems pretty strong still... I dont know.. now I am a bit worried...
Old Jun 17, 2003 | 04:43 PM
MSM69Z28's Avatar
it will need repaired. hope your not planning on putting it back on like that. the balance could be off now and chances of crashing the impellar under high rpms is likely. besides, you've loset some boost and its not worth chancing more shrapnal through the engine. just not sure what your intensions were. kinda sounded like you were wondering if it was ok to put back on and not spend the $$ for the fix. gotta fix it.
later,
mike
Old Jun 17, 2003 | 05:56 PM
Highlander's Avatar
Vortech wants 480... I thought of ditching it and look for a T-trim used over the net in a few days and see...
I am not going to put it back in, I was wondering what could have caused this?
Old Jun 17, 2003 | 06:16 PM
96TurboTA's Avatar
The weird thing is they're all cut in the same shape.
Old Jun 17, 2003 | 06:28 PM
Highlander's Avatar
Yes.. as if something really big got in there for a while and then got out..
Funny enough.. on a friends dragster with huge TTs... a mosquito killed one impeller.. ouch..
Hal Fisher
Sep 30, 2015 09:03 PM
HAWG
Sep 25, 2015 11:41 AM
DelSoto
Sep 19, 2015 05:31 AM
sleeperZ96BT
Sep 10, 2015 08:01 AM
