Zaino process?
Old May 15, 2002 | 03:52 PM
NAKSTOCKZ28's Avatar
Post Zaino process?
should i clay, dawn wash, 3m swirl, then zaino or do i need to wash with dawn again after 3m swirl or can i use 3m swirl without dawning first.
so should i clay, 3m swirl, dawn, then zaino?
01 M6 STRIPPED BLACK Z28 (ONLY OPTION WAS THE REAR DEFOGGER)
KN FIPK installed 02-06-02
Old May 15, 2002 | 04:03 PM
MikeLS's Avatar
Thumbs up
1. DAWN wash
2. Clay
3. 3M
4. Wash with Z7 or DAWN, either will do, I'd choose Z7 though..
5. Zaino away...
*Mike's 1992 Camaro RS 25th Anniv.*
Dark Red Metallic (ext.) / Flame Red (int.)
Flowmaster Crossflow, K&N, 20% 3M Panther Black Tint
JL Audio 3 10", PPI PC2100, Kenwood eXcelon KRC-953H/U, Kenwood / Pioneer speakers
Shine by ZAINO! - Special Thanks to Sal Z!
Old May 16, 2002 | 11:14 PM
Post
but isnt the point of dawning so you can apply the zaino directly to the paint and not old wax.
your method would have me putting zaino on top of 3m.or does z7 get rid of the 3m.
also im using mothers clay bar cause its the only thing i could find. it says to use its instant detailer as a lubricant. should i use the instant detailer, which i have, or should i use a soap water solution.
Old May 17, 2002 | 06:30 AM
Kevin V 2002 SS's Avatar
Post
I'd prefer to use the Dawn to wash off the 3M residue. You can use whatever lube you want to clay, just use ALOT of lube as you clay. You can even mix up a soap solution using the Dawn or the Z-7.
Kevin Villier, 2002 SS #186 - 6M with Hurst and "short-stick", TT, navy blue, chrome SS wheels, Bilstein suspension, SS grill, STB, SLP loudmouth, Direct-Flo lid with Holley filter and Mallory polished MAF ends.
Louisville, KY
Old May 17, 2002 | 08:53 AM
MikeLS's Avatar
Post
Like I said, you can either use Z7 or DAWN to wash off the 3M residue. DAWN is the first process of removing old wax, heavy oils, and silicone buildup (if any) on your finish. The 3M does contain a light oil and solvents for gloss enhancement, but Z7 would have no problem removing those types of light oils, as would DAWN. So, IMO, you can use either. I'd choose Z7 because it will also lay down a thin layer of polish on the suface before your first coat. If you DAWN again after 3M, the soap could leave a film on the finish. Either way, you'll want to do a quick Z6 before you add your first coat of polish.
[This message has been edited by MikeLS (edited May 17, 2002).]
Old May 18, 2002 | 12:00 AM
Post
THANKS
Old May 18, 2002 | 05:56 AM
hcvone's Avatar
Post
Use Dawn after 3M, there is a little silicone in the 3M and the Dawn will do a better job removing any traces of silicone.
Carl V. *****Authorized Zaino Distributor*****
Huntingdon Valley, PA.
2002 Z06 Electron Blue/Mod Red
www.hcvind.com
E-Mail: Zaino@hcvind.com
Formula Steve
Sep 19, 2023 08:31 AM
WobblySausage
Oct 7, 2015 02:44 PM
WobblySausage
Oct 7, 2015 10:09 AM
Sep 18, 2015 03:46 PM
RX Speed Works
Sep 11, 2015 03:31 PM
