Left turn signal does not blink????
Old Jun 8, 2003 | 04:23 AM
Xride's Avatar
Today out of the blue my left turn signal stopped blinking, it turns on, but is solid, not blinking????
the right turn signal works fine, and if I use the 4 flashers they all blink.
What could it be?
Old Jun 8, 2003 | 04:28 AM
eddiezlt1's Avatar
Re: Left turn signal does not blink????
What could it be?
bad bulb on the left side
Old Jun 8, 2003 | 06:37 AM
Compstall's Avatar
Yeah, what he said...
- Brent
Old Jun 8, 2003 | 08:37 AM
19formula94's Avatar
The same thing happened to my right one, still havent figure out the problem. I think it might be something in the wiring.
Old Jun 8, 2003 | 09:24 AM
If you have one side that the turn signal does not flash, it is usually a burned out element in one of the bulbs. Now, if all the elements do work when you use the hazards, try replacing the flasher.
Old Jun 8, 2003 | 09:27 AM
z28jaz's Avatar
Yup, check the bulbs. I had 2 go out in the last 3 months, same thing happened.
Old Jun 8, 2003 | 05:52 PM
Xride's Avatar
Re: Re: Left turn signal does not blink????
Your right, its in the front,
Now how do I go about fixing it?
Old Jun 8, 2003 | 06:35 PM
Thanks for that diagram, when i went to check the flasher i checked the hazard flasher, didnt know there was a difference, THANKS
Old Jun 8, 2003 | 06:50 PM
ixd97z28's Avatar
The buld in my clear corner was out and when I put the blinker on, it would just stay solid in the rear and the arrow on my console. Get those bulbs replaced!
Dan
Old Jun 8, 2003 | 07:50 PM
RUFFIDLNZ's Avatar
Get under the front of the car and you will see some 10mm bolts that hold the plastic covers that bolt up to your bumper cover. Once you take the bolts (10mm) out and drop that plastic piece you can get right to the harness for the bulb. Just turn the harness and connector and pull the bulb out of the housing. Its really easy and you will know what I am talking about when you get down under the front of the car. There are also 2 seven mm bolts that you will need to take off too.
Hope this helps
Old Jun 11, 2003 | 11:55 PM
Xride's Avatar
Hope this helps
thanks for the help, this really made it easy.
My right side went out today, jsut a few days apart... should I be worried, or not till after one of htem goes out again??
Old Jun 12, 2003 | 12:00 AM
Rollin_Sidewayz's Avatar
The same thing happened to me 3 days ago.. its befuddled me also.
Old Jun 12, 2003 | 12:07 AM
94formulabz's Avatar
Make sure the fuggers at autozone give you the correct bulb! thats a real pita wast of time, bulb fits, lights up, just doesn't flash. i won't tell you how much time of mine that wasted.
Old Jun 12, 2003 | 07:51 AM
Xride's Avatar
Just to make sure its a clear bulb #3057?
Old Jul 10, 2003 | 04:59 PM
notstock4long's Avatar
Hey shoebox, where could I get a new turn signal flasher. I know this is a old post, but I didn't want to start a new one just for this. Mine right turn signal does the same thing, it works with the hazards just fine, but when I try to use it by itself it usually just stays solid, but decides to flash once in a while. This also messes with that brake light, and makes it light up differently than the other one. Do you think the flasher is the problem? Thanks again
stangspank
Nov 13, 2015 01:02 PM
CaRParts102
Dec 6, 2014 08:45 AM
vinnyxgunz
Aug 28, 2002 09:41 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
