A4 Transmission Settings
Old Jun 7, 2003 | 06:19 PM
bruecksteve's Avatar
Can anyone share any settings that you're used for your A4?? Advice?
I'm looking at the Down Shift Pressure modifier tables. Does this control the firmness of the downshift?? If so, what kind of value would I enter to make it softer??
Old Jun 7, 2003 | 08:35 PM
96z's Avatar
96z
If you want it softer lower the line pressure.
Are you modified? Does your car make power at or above the current shift point?
You could change that, most people increase their line pressures though...
Old Jun 7, 2003 | 08:58 PM
I autocross my car and would like for the downshifts to be as smooth as possible. That's why I was wondering about the Downshift Pressure Modifier tables. The stock table has zero's in it for the 2 --> 1 downshift. The 3 --> 2 downshift does have some values. It appears it does add or subtract from the main line pressure. I'm just not sure what I should try. I might start with what they have for the 3 --> 2 shift and see what happens.
jmadoll
Mar 3, 2015 10:16 AM
jackpawt883
Feb 26, 2015 09:04 PM
737drivr
Feb 20, 2015 11:54 AM
edxiel
Jan 24, 2015 07:40 PM
CaRParts102
Dec 6, 2014 08:45 AM
