Removing those damn swirl marks!!!!!!
Old Mar 24, 2002 | 07:42 PM
kraka's Avatar
Question Removing those damn swirl marks!!!!!!
I have had my Black 1997 Camaro for almost 5 months and it's gotten a lot of swirl marks since I bought it. I went to the store and picked up Meguiars swirl remover #9, show car glaze #7, and high-tech yellow wax #26. I also got a 100% cotton royal velvet towel for applying all this stuff. So I used the #9 swirl remover first, then a coat of the glaze, and one coat of the wax. It made it slightly better, but I'm still seeing the swirls. I'm guessing that maybe I should have washed the whole car with dish soap to strip off the wax, and then used tons of swirl remover on the bare surface, followed by the glaze and wax. So is this what I need to do to get rid of the swirl marks or am I doing something wrong?
Old Mar 24, 2002 | 07:55 PM
KevinSS's Avatar
Post
I have never had any luck with the Meguiars #9, in the Meguiars line up I prefer the #3 Machine glaze to perfect the finish if you want to stick with the M products.
98% of all cars have swirl marks and fine scratches including brand new cars.
Why? Because of dealer prepping and using an abrasive polish combined with the
wrong towels and incorrect washing of towels. Abrasives and Polyester in towels are
the most common causes of swirl marks and fine scratches, especially on brand new
paint finishes. The dealer is the first person to start the swirl process on a paint
finish.
Here's a way to check if your paint has swirls or scratches. Look at your paint finish under fluorescent lighting. This will let you see every mark on the paint surface.
Then you be the judge.
Store bought Swirl removers are just a temporary illusion and a Band-Aid
approach to the problem.....
I am totally against using abrasives on paint finishes. Abrasives, no matter how fine, create new scratches, they should be avoided and only used when absolutely
necessary. And then only by a trained professional. The clear-coat on today's paint
finishes is very thin and abrasive products will thin it even further and hurt it, in
the long run creating many more swirl marks and fine scratches.
All swirl removers contain abrasives and are loaded with silicone oils and other oils.
Zaino Show Car Polish contains no Abrasives or Silicone oils. Although abrasives
remove scratches they create new scratches and swirls and they thin out the
clear-coat. Silicone oil camouflages swirls and scratches, temporarily, as soon as the
oil washes away or evaporates the swirls are visible again. Kinda a Catch-22. Z-5
fills swirls and scratches and does not create any new scratches. Because Z-5
durability is so high and will not wash away. The scratches will stay filled. That's
the hot ticket to a flawless paint finish.
The Z-5 is applied, as per directions, and will fill swirls and scratches in stages. One
to three coats of Z-5 depending on the amount and degree of scratches. Z-2 should
always be the last coat of polish on the car. Z-2 has higher optics than Z-5. You can
go from Z-2 to Z-5 and back to Z-2 anytime you like. Always use Z-6 "Gloss Enhancer spray between each and ever coat of Z-5 or Z-2.
With deeper swirls and fine scratches sometimes the use of an mild abrasive product
like 3M Foam Polishing Pad Glaze Swirl Mark Remover #39009 is necessary.. I try
to avoid the use of abrasives and would try my best with Z5, to see if it will correct
the problem. However if you don't see a visible difference after 1 or 2 coats of Z-5.
Waiting 6 to 24 hours between coats of Z-5... Then you need to use the 3M Foam
Polishing Pad Glaze Swirl Mark Remover #39009... see following tips...
3M Foam Polishing Pad Glaze use By hand:
Simply apply a small amount (about the size of a quarter) to a cotton diaper or piece
of cotton towel and rub back and forth into about a 1'X 1' section using light to
medium pressure until it starts to dry out. Then take a second towel and lightly rub
back and forth until the polish residue disappears and the gloss comes up. If there
are still some swirls visible you can repeat this step until they are minimal. I prefer
using a less aggressive product a couple times instead of using a more aggressive
product once. After you have done the entire car you can Dawn wash and reapply
your favorite wax/polish or Zaino Z-1 and Z-5/Z-2.
3M Foam Polishing Pad Glaze use By orbital:
Use a 100% cotton bonnet or a foam bonnet and apply the polish in a thin lined
growing circle starting from the center and spacing the growing line about an inch
from the last round all the way to the edge. Place the bonnet flat on a panel and
activate the polisher and begin working the entire panel using light to medium
pressure. When you have worked the panel thoroughly then take a clean towel and
wipe the residue off in a back and forth motion using light pressure. Then simply
move to the next section. When the entire car is done do a Dawn wash and Zaino.
DO NOT ever use cotton T-shirts on your car. They contain polyester and will cause
swirl marks and scratch your paint finish. Use my #314 applicator pad for applying
my polish. Read my Tips & Tricks sheet. www.zainobros.com
Towels must be 100% Made in USA. Name Brand(Cannon or Fieldcrest Towels).
These towels are always 100% Cotton. Most other Brand name towels I've analyzed
are not 100% Cotton but a blend of cotton and polyester. The cotton material is
from overseas and is not federally regulated. Even though they say 100% Cotton
they are not.
You must use only white. Not colored towels.....Colored towels are not to be used
because the dye leaves a chemical residue on the paint finish. Always wash your
towels first before using. Use Liquid detergent and rinse twice. Do not use Powdered detergent, Bleach or any type of Fabric softener. Make sure to run rinse cycle twice to remove all detergent.
You should cut the selvages(borders) off the perimeter of the towels. This selvage
contains nylon and polyester stitching that could possibly scratch your paint finish.
The towels will fray a little once this is done. But it's better to play it safe.
Drying the towels on high heat will make them hold a static charge. I use the regular
heat setting and remove them a little damp and let them air dry. You can fluff the
towel real good when it's dry to make it softer.
As the towels get older they will lose there nap and absorbency and will have to be
replaced.
I don't like sponges natural or synthetic, they all can scratch...
Another great tip is to use a Toro 210mph Electric leaf blower. Dries your car in
about 5 minutes.... without even touching the paint surface....
I prefer The Absorber to dry with if you want to use a chamios.
96 Black Impala SS
Authorized Zaino Showcar Polish Distributor
www.zainobros.com
Remember #3
Old Mar 25, 2002 | 08:08 AM
Luna's Avatar
Post
I alway end up having to do my black 96 by hand to get rid of swirls and excess spiders. Meguiars ShowCar glaze works great by hand.
Old Mar 25, 2002 | 09:23 AM
KevinSS's Avatar
Post
You have to remember, if you use a glaze to hide swirls and scratches, it is just a temporary fix, on the first rain or wash job the glaze will be gone and the swirls will be back, been there, done that.
96 Black Impala SS
www.zainobros.com
Remember #3
Old Mar 25, 2002 | 10:13 AM
MikeLS's Avatar
Lightbulb
Yep, I completely agree with Kevin (as usual )!
As a big Meguiar's user way back when, I've used all the M products you guys are mentioning and then some. Kevin is right, the ShowCarGlaze is nothing more than a blend of oils and very light fillers which will never bond to the surface of the car. Thus, it washes away almost immediately and swirls reappear as before, the cycle never ends. #9 Swirl Remover is just a tad more aggressive than the ShowCarGlaze. #9 is also mostly a filler type product which means after a rain or wash the swirls come right back. I always thought Meg's products worked OK though until I went with Zaino. Now it's easy to understnad the limitations of oil and carnauba based products.
*Mike's 1992 Camaro RS 25th Anniv.*
Dark Red Metallic (ext.) / Flame Red (int.)
Flowmaster Crossflow, K&N, 20% 3M Panther Black Tint
JL Audio 3 10", PPI PC2100, Kenwood eXcelon KRC-953H/U, Kenwood / Pioneer speakers
Shine by ZAINO! - Special Thanks to Sal Z!
Old Mar 25, 2002 | 04:20 PM
Luna's Avatar
Post
Wouldn't the coat of wax after the glazing establish a layer of protection?
Old Mar 25, 2002 | 04:44 PM
MikeLS's Avatar
Lightbulb
The most protection I ever got out of Meguiar's waxes was about 1 month or less. I used #26, Medallion, and Gold class as final wax protection and none of them ever lasted longer than a month through normal driving, washing, and rain. Their waxes shine pretty well, but have very poor durability. After just a few weeks, even the wax is gone and swirls will pop back up again. It really is a losing battle with carnauba and oil based products. That's why I got fed up with that whole cycle of having to pain stakingly rewax with Meg's.
Old Mar 27, 2002 | 12:01 AM
OLDDIRT's Avatar
Post
Will zaino work well on the gelcoat of my searay, meg's doesnt last very long
Old Mar 29, 2002 | 05:33 PM
96z's Avatar
96z
Post
<font face="Verdana, Arial" size="2">Originally posted by OLDDIRT:
Will zaino work well on the gelcoat of my searay, meg's doesnt last very long</font>
I dont see why not, it works with everything else
96 black Z28 A4
GTP stage II heads, GTP 226/230 cam, 11:1 CR, Pro Torque 2800 TC, Tranny cooler, 3.42, 1.6 rr, Holley 58mm TB, Hooker LT's, SLP CAI, cutout, Wolfe cage, Carrera's, 5 point belts
Performance work done @ Mattucci Motorsports
WNYFA FLFB
Pics for now
NewsBot
Apr 7, 2015 10:50 AM
ChrisFrez
Dec 7, 2014 11:32 AM
Tibbys96Z
Aug 12, 2001 04:23 PM
LurkerLS1
Aug 9, 2001 03:55 PM
1995formula
Aug 8, 2001 08:58 AM
