Winshied Fluid Nozzle/Window Motor Problems
Old Jun 5, 2003 | 09:34 AM
bigsteve7's Avatar
2 problems..
My drivers side fluid nozzle has stopped working. When I try to spray my winshied, it barely shoots fluid at all. The passengers side works great though.
I looked at the nozzle and it looks as if you can pop it out with a small screw driver or something. Is that how it works, or do I haev to remove the whole plastic piece from around the base of the winshield? I'm hoping I can just pop it out, go down to my local chevy dealer and purchase a new one. Any ideas on this?
Also, my passenger side window motor is on its way out. Ive read this is a common problem. Is my best bet to go down to the dealer adn get a stock replacement, or try to head to my local pep boys/advance auto etc. and try to find a replacement there.
Old Jun 5, 2003 | 09:38 AM
RTICWOLF's Avatar
On the issue if the nozzle, disconnect the line right at the washer pump in the fluid bottle.
Your lines are probably plugged with some sort of "crap". Take the end of an air hose with the trigger type blower and put it on the end of the hose you just removed. DO NOT use full force (you can blow a line off somewhere), just enough to hear and see the crap spray all over your windshield. Plug the line back in and you should be good to go, if not, use a little more pressure and do it again.
Both nozzles should spray about the same once they have been cleared and you will be amazed at the crap that comes out. Easy and free fix!
Old Jun 5, 2003 | 02:17 PM
RENE95Z's Avatar
I had the same problem with the passenger side nozzle. All I did was take a straight pin and stick it in the hole and wiggled it a little and pulled out a little trash. Voila, the nozzle works again. I would try this before shooting air through the lines.
Old Jun 5, 2003 | 08:46 PM
bigsteve7's Avatar
Alright, I'll try taht tomorrow, thanks.
Earlier today, I went to go spray air through the lines and couldnt figure out how to get that pump out of the resivoir. I thought I could just squeeze my fingers down there and pull it out but no such luck. I guess you have to unbolt all that metal above it? Thats a pain in the butt for just trying to get to a little winshield sprayer pump. What were the engineers thinking?!
Old Jun 30, 2003 | 10:09 AM
SSCamaro's Avatar
If anyone was noticing the smell of crack comming from the bathroom on thier breaks.
PCLZ28
Dec 24, 2015 05:19 PM
alex5366
Feb 17, 2015 10:43 PM
jb4xx
Feb 2, 2015 10:00 PM
FredM
Dec 18, 2014 01:40 PM
