how to replace coolant sensor
Old Jun 2, 2003 | 04:14 PM
scottslt1z28's Avatar
exactly what the title says.
How do you replace the coolant sensor?? My low coolant light is on, but i dont have low coolant. I figured this is what is wrong. Thanks guys!!
Scott
Old Jun 2, 2003 | 04:35 PM
TTT
Old Jun 2, 2003 | 04:40 PM
transamtom's Avatar
Its tight to reach,at least for me it was.
Get your new sensor,look at the clip,its on the inside,this will show you how to get the old one off.
Unplug the connector,then slide the metal wire clip back,and pull off the sensor,coolant will spill,you may want to catch it in a small pail under the car.
Slide the new one on and reclip it.
Do this with the engine cold.
Take off your rad cap and top up the rad,run your car until the thermostat opens and bleed your air out with the bleed screws.
Old Jun 2, 2003 | 04:53 PM
VegasZ's Avatar
Access is much easier if you remove the battery.
Old Jun 2, 2003 | 05:29 PM
94ZVert's Avatar
I just unplugged the sensor and check the fluid periodically. Takes 1 minute, it's free, and if you do routine maintanence you shouldn't have a problem. My .02.
Old Jun 2, 2003 | 05:32 PM
well i already bought the sensor, i might as well replace it
Scott
Old Jun 2, 2003 | 05:43 PM
94ZVert's Avatar
Cool, well try this link...
http://csce.uark.edu/~jgbertr/rb/low_coolant2.jpg
Dan_the_ManZ28
Feb 21, 2015 02:01 PM
phoenix95
Jan 8, 2015 02:44 PM
phoenix95
Jan 8, 2015 09:14 AM
AlaskaZ28
Jan 1, 2015 12:30 PM
91Bird305
Aug 8, 2002 12:36 AM
