THUMP THUMP THUMP under HARD accel..
Old May 30, 2003 | 05:00 PM
OLDDIRT's Avatar
Im getting a load thumping noise from the trans tunnel during lauches and shifts (A4), any help would be appreciated. John A EDIT: ya ya, i meant LOUD not LOAD.lol
Old May 30, 2003 | 05:12 PM
Kris93/95Z28's Avatar
Tranny mount
Old May 30, 2003 | 05:15 PM
OLDDIRT's Avatar
If it is a trans mount should I replace with stock or aftermarket and what brand. Thanks, John A
Old May 30, 2003 | 05:20 PM
I replaced mine with a stocker and broke it shortly thereafter, so I went with the 1LE mount from GM. It has worked great for over two years now
But others suggest a good poly mount. Do a search on this subjest and I'm sure you'll find more than you need since these cars break the stock pieces very quickly
Old May 30, 2003 | 05:22 PM
SWINGRRR's Avatar
I would for sure say tranny mount. If you do a search you will find mixed feelings about the poly mount over the stock one. Some say it relay's more vibrations into the car, other feel it is fine. I replaced mine with a stock one. A buddy at a local shop did it and a trans service, fluid, filter, and all, for about $60 total.
Old May 30, 2003 | 05:27 PM
No offense BUT I would never go back to a stock mount. I broke two in about a week, and I have yet to break the 1LE. I would at least get the 1LE, when replacing the mount. This is just my opinion.
Old May 30, 2003 | 05:59 PM
chevyboy_z28's Avatar
heres my story ive broke (2) stock mounts, (1) 1le mount, and im working on this poly one. i had a little more trouble breaking the 1le (hence it is a little stronger than the stock one, but if you do any real "hot-doggin" then youll break it too in time!), i dont keep breaking these things on purpose its just that i do things like donuts, holeshots coming off corners, racing every car i see, etc. if you drive anything like me youll do best with an Energy Suspension (brand) polyurethane trans mount!
the myth about how poly mounts create unbearable vibration is nothing more than a myth! it does vibrate however but not to the point where youll hate to get on the freeway, personally i like the vibration and it makes my exhaust rumble a little more. also the tone of the whole drivetrain is increased which is another thing i like so if and when i break somethin (ie. inside the trans) i will be able to hear it!...this post got a little long but i hope it helps you out!
CONGRATS!!!!!!!!!...you just broke your 1st mount!
Old May 30, 2003 | 07:06 PM
OLDDIRT's Avatar
Thanks for the help guys, i think Ill try the poly mount, Im putting new tires on it next week and was making sure they old 1s were 100% used up.lol
93 RedBird
Nov 15, 2015 08:24 AM
Bxlt1
Sep 29, 2015 03:18 PM
Daluchman1974
Sep 11, 2015 06:12 AM
Matt Dreessen
Sep 9, 2015 09:58 PM
