How to clean a white convertible top
Old May 27, 2003 | 12:03 PM
mc2001ta's Avatar
Question How to clean a white convertible top
I bought some top cleaner for my buddies convertible top but did pretty much nothing for his new white top. We used a lil bleach with water and it did a little for us. BUt there still is quite a bit of work to do.....what should we use. Let me know cleaning gurus
Old May 28, 2003 | 08:10 AM
mc2001ta's Avatar
Angry
thanks for the reply........good to know NOT to use bleach! Guys, somebody has to have a white top that knows some type of solution. My boy's car is about 6 months old and already there are dark streaks in the top along with the white color turning brown/yellow. Please respond, we need help bad
Old May 28, 2003 | 10:35 AM
LaSSt One's Avatar
Haartz makes our tops. This is what they recommend for cleaning them. For their website:
CAMBRIA®, STAYFAST, TWILLFAST®
Solution Dyed Acrylic Topping Fabric
Ordering Information at bottom of page
Although the fabric does not promote mildew growth by itself, mildew may develop on dirt and other foreign substances that are not removed. This is especially true in warm, humid, dark environments. A program of keeping the fabric clean through regular washings, BEFORE it gets dirty, will enhance the life and beauty of the acrylic and make successive cleaning easier.
Most automatic car washes will not harm cloth top fabrics. Washes with water jets and hanging cloths provide a more gentle cleaning action. Those using heavy barrel brushes could damage the top material. Haartz recommends hand washing.
The Haartz Corporation recommends using RAGGTOPP™ Cleaner and RAGGTOPP™ Protectant (available from Wolfsteins Pro-Series at tel: 800-377-4700, fax: 770-395-1353, e-mail: info@wolfsteins.com).
Hand washing in shade or partial shade, not direct sunlight, is best. DO NOT USE DETERGENT. Bird and tree droppings, as well as other loose particle soils, should be removed immediately. Vacuum with a brush attachment and rinse thoroughly with water to remove loose particle soils. This will also prevent the soils from being redeposited during the cleaning process. Once the fabric has been rinsed thoroughly, spray RAGGTOPP™ Cleaner evenly over the entire surface while still wet. Allow the cleaner to soak for 10 to 20 minutes and then scrub lightly with a soft nylon brush or terry cloth rag. Rinse thoroughly, preferably until no remaining soap foam is observed. Additional cleanings may be required. It is best to determine the need for additional cleanings after the fabric has dried completely.
Washing with soap (ie. Ivory or Lux) and warm water is a safe alternative to RAGGTOPP™ Cleaner, but not as effective.
For more stubborn cases, mix a solution of no more than 1/2 cup (4oz.) bleach and 1/4 cup (2oz.) RAGGTOPP™ Cleaner per gallon of water, soak for approximately 20 minutes and scrub lightly as indicated above. (Excessive soaking with the bleach solution can deteriorate seam threads.) Rinse thoroughly to prevent streaking on painted and chrome surfaces. Several cleanings may be necessary.
Once dry, cleaning must be followed by re-water repelling with RAGGTOPP™ Protectant. (This product does not contain CFC's and therefore, is not harmful to the environment.) Failure to apply will result in rapid resoiling of the unprotected fabric.
For ordering information contact www.wolfsteins.com
Stayfast®, Twillfast®, and Cambria® are registered trademarks of the Haartz Corporation
RAGGTOPP™ is a trademark of Wolfsteins Pro-Series
© Copyright 2002 The Haartz Corporation
Old May 28, 2003 | 11:08 AM
mc2001ta's Avatar
Talking
Brian thanks a bunch that looks like it may be about my best shot at cleaning this white top. Thanks again
WildRidez
Feb 23, 2015 07:24 PM
nosliw
Feb 7, 2015 01:30 PM
Omega9
Aug 17, 2002 04:23 PM
Omega9
Aug 14, 2002 10:59 PM
Omega9
Aug 14, 2002 07:55 PM
