Attn: norcalstreet; Need Rear End Help!
After attempting to replace a wheel bearing, I have accepted failure, and am frankly having a fun time putting everything back together. But To remove the axle, I had to unscrew the retaining pin from the diff, and then remove the big pin/block from the center of the diff. Thing is, I don't remember which way it goes back in!!! Either way, the diff still operates, I think it's just for lubrication but I wanna get it right. Can anyone describe how it goes into the diff? If you need a pic to refresh your memory I have one. Thanks a lot!!!
It fits both ways! The designs(hole and slot) on the block are not symmetrical, so if I put it in one way, they will work correctly, and the other, they will not and I will probably fry my diff. The block fits in both ways and the pin holds it in both ways too. I don't know how the slot and the hole in the block work so I cannot make an educated descision, and most of the time when the chances are 50/50, I get it wrong.
No I didn't remove the differential. I gave up and will take it to Midas or someplace similar.
I figured out how to put the block in with a pic someone sent me. It does have more function than just holding in the c-clips, or it wouldn't of been machined in such an intricate way. It actually scoops up oil a throws it over the gears inside the diff. Wouldn't be that important if I got it in wrong though. Thanks.
