Midwest Illinois, Indiana, Michigan, Ohio, and Wisconsin
Chag Beebe*** Driveshaft info inside.
Old May 25, 2003 | 11:21 AM
Redbird's Avatar
Talking Chag Beebe*** Driveshaft info inside.
There is a little shop in Concord MI that can make you a driveshaft.
It's called A&I Balancing... (517)524-8655 13300, M-60 Concord.
You might check with them. They have done work for me in the past and are very knowledgable. Good Luck!
HInk
Old May 25, 2003 | 01:36 PM
Grover's Avatar
Thanks Kevin.
It's Chad with a "d" not a "g"
Old May 26, 2003 | 09:58 AM
Redbird's Avatar
Arrow Well...
... After blowing your ALUMINUM shaft to smitherines, in front of hundreds of people, I thought you just might want to change your name, Gropper!
HInk (Real Smart Azz Today)
Old May 26, 2003 | 11:22 AM
Grover's Avatar
Check here for other people that use ALUMINUM driveshafts for drag racing. I think I got the lower version instead of the Metal Matrix Composite Aluminum version.
Old May 26, 2003 | 02:05 PM
Redbird's Avatar
Question Chad... Dangitalltoheck...
I CANNOT FIND THE WIRE TO TIE MY 4 BRAKES TO THE SWITCH.
DO I LOOK UNDER THE DASH? I found a relay under there but when it isn't plugged in the car won't start. Am I looking for something that will only give a 12 volt signal if the brake pedal is depresses??
HELP I am a STUPID SOB
HInk
Old May 26, 2003 | 03:14 PM
Grover's Avatar
Yes you are looking for a wire that supplies 12V when the brake is pressed. I would guess it would be under the dash.
blac94Z
Nov 4, 2015 01:59 PM
colts0455
Oct 4, 2015 09:47 PM
drt
Sep 27, 2015 04:39 PM
frankrizz
Sep 23, 2015 04:21 PM
CARiD
Sep 7, 2015 08:21 AM
