3M 39009 vs. Z6?
Can't find the 3M stuff anywhere locally, even at Pep Boys, so may settle for the Z6. Anyone tried both products? TIA.
Daily-driven 383 M6 featured in the 10/00 Car Craft.
"Real men drive opposite lock."
Thats really comparing apples and oranges. 3M-39909 is a light abrasive designed to remove scratches and swirls. Z6 is a gloss-enhancing spray. Perhaps you meant Z5, the swirl mark reducer? If so, I've used Z5 with great success on light scratches. But I've never used the 3M stuff. Even so, I have seen it at Pep Boys and Napa.
Chris a.k.a DJ Cobol or NuknFutz99
No F-body yet!
<A HREF="http://www2.gvsu.edu/~stigersc/lakepics.htm" TARGET=_blank>'97 Cutlass Supreme SL coupe - Bright Red
</A>
No F-body yet!
</A>
Ooops, the comparison should read 3M 39009 vs. Z5.
<font face="Verdana, Arial" size="2">Originally posted by Jim S. '95 Z28:
</font>
</font>
3M 39009, abrasive polishing compound, to remove scratches (and paint) and to leave no protective coating on the car
Z-5, synthetic paint protector, totally non-abrasive, fill scratches instead of removing paint, will leave a protective layer on the paint.
96 Black Impala SS
Authorized Zaino Showcar Polish Distributor
www.zainobros.com
Remember #3
</font>
</font>
http://www21.3m.com/dr/v2/ec_MAIN.En...840&CACHE_ID=0
You can also get 3M products at any store that supplies body shops.
96 Black Impala SS
www.zainobros.com
Remember #3
Thanks for the link!
Kevin,
Read all about the 3M Swirl Mark Remover by searching/reading past threads, but still have a few questions. If the finish on the rest of the car is brilliant, will the 3M polish dull the paint like coventional paste abrasive compounds like Turtle Wax?
While it's difficult to guage w/o pictures, which would work more effectively for moderate swirls?
Kevin,
I'm not Kevin, but I have some input.
The 3M did not dull the finish on my Cadillac's white hood after using it. Although, I promptly washed it off with Simple Green, then put a new layer of Z1/Z5 afterwards, which really added to the shine.
To answer your question, on my white hood, the 3M did not dull the paint. It made it brilliant, in fact!
Solomon
Life...what's the point?
Silver '95 Camaro Z28 M6: 14.3 @ 98.7 - Will improve!
White '90 Cadillac deVille: 16.3 @ 81.4 - Static for now.
Learn how to tune your LT1 PCM!
Solomon
How about a dark paint (Polo Green)?
</font>
</font>
96 Black Impala SS
www.zainobros.com
Remember #3
Gonna order some up ASAP. Any tips on how to use it properly? Thanks.
</font>
</font>
Basically you apply a few drops of the compound per square ft. then work it with the buffer till it almost disappears. Eventually it'll dry completely and leave a slightly dull residue behind. Just wipe that off and move on to the next section.
I have the same color car as you and the 3M stuff worked quite well. It gave the paint a very smooth finish and a nice shine. Just remember to wash the car when you're done and to apply some form of wax/polish soon. The 3M stuff will strip the paint bare so you'll be without protection till you rewax/polish it.
Good Luck!
Jason
93 TA, M6
[This message has been edited by Soma07 (edited October 07, 2001).]
NewsBot
Jul 3, 2015 02:10 PM
NewsBot
Jan 29, 2015 07:10 PM
LILBLKZ28SS
Aug 16, 2002 08:34 AM
Casey96SS
May 24, 2002 09:23 PM
