Can custom cam make 450+rwhp w.AFR heads
Old May 22, 2003 | 06:27 PM
MadMaxz28's Avatar
i have 195cc AFR heads w/ comp port that flowed right on target with AFRs website. right now i have a XE 236242 shelf cam and want to look into custom grind cams after ready treys post about choosing a cam.. im learning the lingo but im still lost on what will work for me. i really love the 236 242 cam in my mostly daily driver car.. but i think i can handle more power if i can retain drivability... i really want to make close to 500rwhp (made 410 with XE cam). if jordan did it i wanna do it!! anyone with some ideas shoot um out.
Old May 22, 2003 | 07:14 PM
rskrause's Avatar
Moderator
You are gonna need high compression and a solid roller to make 500rwhp with daily driver drivability, IMHO. Not knowing your CR, it's a bit difficult to make hard and fast recommendations. But if you must use a HR, you are gonna need a big one. Maybe the XE lobes #3317/3319 which give 294/306 adv, duration and 242/254 @ 0.050". Lift is 0.576/.619" (1.6). 110LSA with 4 degrees of advance ground in.
I don't know of anyone running this, just off the top of my head. It won't have much power until 3,00-4,000rpm.
Rich Krause
Old May 23, 2003 | 08:35 PM
MadMaxz28's Avatar
yeah i do have high compresion.. ii believe its 11:1, flat top pistons and the smallest cc 195 afr head.. but if i go solid how often do i have to adjust the valvetrain. how bad will a that big of a cam hurt drivability. 12k miles a month
Old May 23, 2003 | 09:10 PM
CGrant's Avatar
Is that a typo? 12k/month
You need to go get yourself a hundai or something as a daily driver, Hell go get yourself a $700 *** crap, those type of miles are murder on that stroker, Way too much money in that motor to drive it daily if it was me. No offense JMO!
Take care...
Chris.
Old May 23, 2003 | 11:41 PM
rskrause's Avatar
Moderator
The general "rule of thumb" is that a SR "acts" like an HR of ~5 degrees less duration. IOW, a SR with 240 @ 0.050" will drive like a HR with 235 degrees at 0.050". In a high CR motor, a big cam has much less of an adverse effect than in a lower CR setup. But in this context, 11:1 is not "high". People running big cams NA sucessfully on the street at in the 12.0:1-12.5:1 range.
Most people I know with a street solid roller do an adjustment after a couple of hundred miles and once or twice a year afterwards depending on how much they drive and how hard they push the motor.
Rich Krause
Old May 24, 2003 | 05:45 AM
MadMaxz28's Avatar
that isnt that bad... get my heads hand ported, new springs/stronger valves + solid roler could put me close to 500rwhp. the i could run with na stroked ls1's!
LeftoverChinese
Jan 14, 2024 03:03 PM
F'n1996Z28SS
Aug 23, 2023 11:19 PM
InfernalVortex
Jan 17, 2015 09:35 AM
CARiD
Jan 14, 2015 04:00 AM
