summer is back, car runs hot again
Old May 22, 2003 | 04:33 PM
Azimiut's Avatar
I know it is summer and it is already 108* today. but my car runs HOT! what would help? I am planning on a E Water pump, oil cooler? 4 core Rad? i think that i am on the right path. any help would be appreciated! thanks
Old May 22, 2003 | 04:39 PM
97bowtie's Avatar
Do you have your fans programmed for the 160* thermostat? I have a 160* stat and have the fans programmed and my car runs around 185* most of the time. Hope u get it figured out.
Old May 22, 2003 | 04:49 PM
pennys58's Avatar
I would agree with 97bowtie. As long as you're retaining coolant and your fans do come on, then yes I would get the parts listed. But if the fans aren't comming on, then either get a manual switch(I have one and solved my problem completely) or have it programmed. Mine use to get hot ALL the time to the point I would think, in traffic, I would have to pull over and let it cool. You may also try getting the coolant system flushed and refilled. I also did that and helped a ton. That's my .02
JOHN
Old May 23, 2003 | 11:32 AM
Azimiut's Avatar
I had done all of the above last year, new coolent, new 160* therm, and fan switch.
Old May 24, 2003 | 12:35 AM
ATMINF's Avatar
When I first got to FT Irwin(it is just below Death Valley) I put in a Griffin radiator, it has never came close to getting hot again. The highest it has gone was 1/8 below the 1/2 way mark. If you get a griffin I can tell you that you will not have to look at you temp gauge and worry in traffic again. I have also made many stop and go trips to LA in rush hour traiffic and not issues.
Collector Car
Dec 17, 2014 01:12 PM
ro2207
Dec 4, 2014 06:18 PM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Brent94Z
Mar 21, 2002 04:44 PM
