Coolant rushing into "overflow" after car is turned off....
Old May 18, 2003 | 10:00 PM
BOWTYDE's Avatar
When I turn off the car once and a while I hear coolant rushing into the overfull thing... is this because the shop I just took it to overfilled the system??
Old May 18, 2003 | 10:08 PM
burnemonm1's Avatar
your car actually heats up after you shut it off because your fan is not on and your pump isn't pumping I hear coolant moving in all my cars after the get shut off.
Old May 18, 2003 | 10:09 PM
BOWTYDE's Avatar
but if this is normal how come I have never heard another f-body do this before???
Old May 18, 2003 | 10:11 PM
burnemonm1's Avatar
all three I have driven have done it
Old May 18, 2003 | 10:24 PM
Ghettoraid's Avatar
If you're worried about it ... grab an Apex'i turbo timer... It also has A/F and Voltage gauges built-in... they're around eighty bucks...
Considering the fact that it serves the same functions as two gauges, AND gives your car a few minutes (you can set the time) to cool down, it's definitely worth the money...
Old May 18, 2003 | 10:55 PM
You could always replace your radiator cap. It might be weak and allowing coolant to pass to the reservoir at a lower than intended pressure.
Old May 19, 2003 | 02:19 PM
Eddie95Z28's Avatar
Simple but it happened to me. Check to make sure the overflow tube and the tube from the TB aren't switched. they are similar in size and easy to mix up. I don't know why they would have removed them... But it can't hurt to check.
Old May 19, 2003 | 02:31 PM
CamaroBoy96Z28's Avatar
Only be worried if coolant is pouring out the overflow resovoir. Mine did that because of a leaking hose. Pressure in the system causes coolant to rush into the overflow resovoir. Just do the obvious checks. Like Shoebox said check the radiator cap and look for any kind of leaks in the hoses.
These LT1 cooling systems...
Old May 19, 2003 | 02:42 PM
teke184's Avatar
i'd put money on the radiator cap as well. SAME EXACT thing happened to me. the caps wear out, since the lt1 coolant system needs 18lbs of pressure.
a new cap is like $5
cured the problem immediatly.
calaban
May 18, 2020 06:43 PM
liamcg97
Nov 25, 2019 05:55 PM
brentbrowning01
Dec 16, 2014 06:35 AM
CaRParts102
Dec 6, 2014 08:45 AM
USAirman93
Nov 24, 2014 03:37 PM
