couple lt4 questions
Old May 15, 2003 | 07:36 PM
b1ack95z28's Avatar
Can i use the lt4 intake manifold with out the heads?
And can i use the lt4 hot cam with out the heads, and if i can wheat else will i need to install it?
Old May 15, 2003 | 08:19 PM
b1ack95z28's Avatar
ttt
Old May 15, 2003 | 09:45 PM
b1ack95z28's Avatar
can i please get some help?
Old May 16, 2003 | 12:08 AM
TimbrSS's Avatar
Re: couple lt4 questions
No, the ports wont match up.
You don't need new heads, just new valve springs. 1.6 RR's would be nice to add too while you are at it.
Old May 16, 2003 | 12:19 AM
95z28 -quicksilver's Avatar
From: Austin, TX or Texas State University at San Marcos
Just get the LT4 hotcam kit from jason cromer for 475. Hotcam, 1.6 RR's, and LT4 valve springs. Good price and kit. I am a little bais though.
Chris
Jason Cromer - 1-850-243-8826 (parts line)
Old May 16, 2003 | 12:35 AM
TCAL95Z's Avatar
I think the LT4 valve springs are not the best choice. I used them for a couple years but most builders say they come very close to coil bind. I replaced them with Isky springs from Thunder Racing. Also the Isky springs fit on the heads better
I would NEVER put the hot cam in without 1.6 rr's and I don't think I would even put in a cam again without porting the heads.
Especially if you're not doing the work, if you have things torn down far enough to do the cam you should just spend the extra money and do the heads because you will save a lot of install money by doing everything at once.
Old May 16, 2003 | 10:20 AM
b1ack95z28's Avatar
will i need lifters too? And how much is it ussually to get my heads ported?
Old May 16, 2003 | 10:33 AM
LT1derful's Avatar
Lifters are arguable...again, as someone said...you've torn it down far enough, you'll save doing it all at once. For $200 or less and probably a minimal labor fee, lifters would be wise. Also, not sure if your 95 has the hardened pushrods, might want to check into that. If not, a set of those would be reccomeneded.
Heads; anywhere from $500 (just port/polish) to $2000 or more with valve job.
Lemme pimp some Phil; www.advancedinduction.com he's got pretty fair prices, and his heads seem to be making good #s!
ModdedNerd
Jan 29, 2015 07:23 PM
95chwagon
Jan 13, 2015 09:19 PM
ChrisFrez
Jan 4, 2015 08:43 AM
96z
Aug 2, 2002 09:00 PM
