clutch slave cylinder
Old May 13, 2003 | 07:07 AM
toddfather's Avatar
Angry clutch slave cylinder
My friend has a 95 LT-1 Z-28.His clutch slave cylinder he thinks is bad.Will not go into gear.He says it was at the top of the pedal just before it "crapped the tights".Neither of us know to much about hydraulic clutches.does anyone have any clues as what went wrong,or how to fix it?
Old May 13, 2003 | 01:57 PM
cals400ex's Avatar
the hydraulics can just go bad over time. the slave and master cylinder and resevoir come all together. they come with lines prebled and full of fluid also. all you have to do is take your whole assembly off and put the new one on. the gm part # is 12557509. it usually runs around $100.
Old May 13, 2003 | 04:09 PM
toddfather's Avatar
thanks we got the old one off.next is the fork suppost to have any play in it.it seems a bit sloppy.we are concerned that there may be more damage to internal parts. thanks for the help
Old May 14, 2003 | 01:15 AM
cals400ex's Avatar
i am not to sure about the fork. i do know that some people have had problems with theirs though. when re-doing a clutch setup, many people replace the throw out bearing and the pilot bushing for maintenance. also, a few people had a problem with one of the springs coming out of place or even a spring breaking and this causes their cars not to go into gear. i also have this problem every once in a while and i don't know what it is.
Old May 14, 2003 | 01:49 AM
96speed's Avatar
The fork will have a little play in it. You can pull it down (disengage) and push it back up onto the throwout bearing (engage) to make sure its in the right place.
Ryan
sleeperZ96BT
Sep 9, 2015 08:28 AM
raroz28
Sep 8, 2015 06:10 AM
sherwinZ28
11
Aug 15, 2015 05:38 PM
karpetcm
Aug 14, 2015 03:02 PM
NewsBot
Jul 8, 2015 06:47 PM
