60' times
Old May 11, 2003 | 02:18 PM
cformulaowens95's Avatar
Angry 60' times
what can I do to drop my 60' times last night I ran a 14.4 with a 2.5 60' here is what I am thinking. just give me an opinion on what might work to drop my times....
lower control arms
4.10 gears
drag radials
learn to drive a six speed
I know my car with mods done to it is def. faster than this, on the street I run dead even with 13 sec LS1's
Old May 11, 2003 | 02:39 PM
jeff1586's Avatar
i wouldnt mix 4.10 gears with drags in a stock rear end. just a couple of days ago my friends ls1 rearend was blown after install of 4.10s and 275 bfg drag radials. do you spin the tires alot at launch?
Old May 11, 2003 | 02:43 PM
boxerfreeflow00's Avatar
u got too get some new tires
try drag radials
drag slicks could f*ck up your rear
i got 2.0 60' with mods listed below
i don't spin with street tires
Old May 11, 2003 | 02:49 PM
boxer the only problem I see is that you have a A4 they don't spin as much off the line if you warm the tires unless you are dumping from nutruel to drive (no reason to do that) I figure I'm gonna buy some toyo drag radials to try out sad enough to say but i'd be happy with a 2.0 60' yeah if I don't bog out of the line i spin all thru first and into second some so it's def. a traction issue, so keep it coming guys
Old May 11, 2003 | 03:00 PM
LT1derful's Avatar
Got a 1.92 60' with stock 3.42s, ET streets and 4000RPM clutch dump.
HectorM52
Jul 30, 2017 11:46 AM
Feffman
Oct 9, 2015 05:42 AM
ChrisFrez
Feb 1, 2015 08:26 AM
capebuf
Jan 13, 2015 07:22 PM
