Tons Of Questions..... Wana Help Me Out
Old May 10, 2003 | 12:35 PM
SilverBulletWS6's Avatar
-If you have an exhaust leak off the exhaust manifolds, would that set a bad o2 sensor code? so the sensors might be good, its just detecting the leak?
-anyone ever heard of these brake pads? Hawk Ferro Carbon Racing Compound front disc pads for your 93-97.......are they any good? i gotta replace my break pads and i can get these dirt cheap? i dont wana do an ls1 upgrade or anything i just need to do a cheap brake change.
-I have a 96 t/a ...........if i could get a 97 instrument gague panel from a t/1 .....what all would be required to do the swap.......any info/links or pointers wold help.
-what is the part# for MSD Stock Replcement Ignition Coil?
-i know i have more question......i just cant think of them right now.....all help is appreciated
Thanx in Advance
Old May 10, 2003 | 12:43 PM
nateh's Avatar
The exhaust manifold leak would allow oxygen into the exhaust stream. This would throw off the O2 sensor readings and you would see a false lean condition. It shouldn't cause failure. You could have both a leak and a bad O2. You could swap sides on the O2's and see if the code follows.
Others will have to chime in for your other questions.
Old May 10, 2003 | 12:51 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
Re: Tons Of Questions..... Wana Help Me Out
Thanx in Advance
yes
yes, good pads
no clue
forgot
np
Old May 10, 2003 | 01:48 PM
Dr.Mudge's Avatar
Double check on that MSD coil, alot of people have had bad luck with them.
Old May 10, 2003 | 05:35 PM
MSD single connector coil for 1996-1997 is #8231. MSD did seem to have a bad run of the pre 96 #8226 coils and a couple of other manufacturers had similar failures. Most or all were easily replaced under warranty. I have not heard anything bad regarding the #8231.
Old May 10, 2003 | 07:38 PM
anyone got any input on the brake pads? i went to there website
http://www.hawkperformance.com/material_description.cfm
and they are the dr97 compund......i was wondering if they are gonna sqeak, whine or any of that....... also i just need do a stock replacemnt.....i drive the car everyday and its not a monster....so i just need somehthin that will take some abuse and basic daily driving but at the same time be a cheap stock replacemnt[I dont want to spend and arm and a leg]....... anyone got any input? or recomendations
RUENUF
Mar 13, 2016 03:37 PM
Hal Fisher
Sep 30, 2015 09:03 PM
alliance12364
Sep 23, 2015 12:40 PM
alliance12364
Sep 17, 2015 08:43 AM
WPHIG2
Aug 27, 2015 06:37 AM
