When you delete the AC do you need to plug anything??
Old May 4, 2003 | 11:22 PM
96z's Avatar
96z
When you delete the AC is it as simple as removing the compressor, condensor, etc? or do you have to plug "area's" up?
Old May 5, 2003 | 07:17 AM
IDOXLR8's Avatar
I did not have to plug anything when I removed my AC. I replaced the condensor with a 1LE AC delete bracket.
Old May 5, 2003 | 10:14 AM
BPS's Avatar
BPS
nothing to plug, the ac delete bracket is required of course and some folks fill in the side spaces once the condenser is removed to help direct the air through the rad. This is optional - I did not do it and have no problems.
Some folks also remove all the ac equipment into the heaters controls - I revoved all the components to the connector near the PCM that has the 2 pipe connection, I couldn't be bothered ripping into the heater core and all that.
Old May 5, 2003 | 11:01 AM
GREGG 97Z's Avatar
I was going to yank my a/c this weekend, wouldn't you want to plug that 2 pipe connection to keep the system clean if you ever decide to reinstall it? I was going to plug that up along with all the plumbing I removed, you don't want dirt, debris or moisture to get in there if you ever plan to reuse it.
BTW, does anyone have a guide on this procedure, it seems pretty straightforward, just checking though before I tear into it.
Old May 5, 2003 | 11:21 AM
BPS's Avatar
BPS
You could, but you don't have to
I never plan on reinstalling it - so it wasn't an issue for me
Old May 5, 2003 | 11:49 AM
Dr.Mudge's Avatar
You could put some tape over it or something, mine looks perfectly clean and I haven't had AC for at least 18 months.
Old May 5, 2003 | 11:52 AM
96 WS6's Avatar
I was just about to post this but I saw this on the 1'st page... I just ordered the 1LE A/C delete pulley yesterday. Is there an writeups?? How many hours am I looking at? Do I need a new accessory belt? Thanks.
Old May 5, 2003 | 01:38 PM
96z's Avatar
96z
Where are these "side spaces" you are referring to?
Old May 5, 2003 | 02:17 PM
The condensor is "sandwiched" between the plastic baffle and the radiator (the baffle guides air from under the nose to the condensor/radiator). When you remove the condensor, the plastic baffle ends up about 1" away from the radiator, and air might leak out the gap, rather than going through the radiator. The baffle is sort of flexible so you can force it back against the radiator, or you could put a strip of weatherstrip in ithe gap, or you can just leave it alone. I left it alone and don't have any cooling problems.
Old May 5, 2003 | 02:18 PM
96z's Avatar
96z
I see Fred. I left this piece off too after I couldnt figure out how to get it back on with that huge gap there....Ill see if I can figure something out...
HarleyZ28
Oct 5, 2015 06:23 AM
FredM
May 28, 2015 04:28 PM
BLK1997Z28
May 7, 2015 03:01 PM
armedtrigger
Feb 24, 2015 08:30 PM
cmdeshon
Dec 27, 2014 10:06 AM
