Has anyone used the tire "softener" treatments
Old Sep 5, 2002 | 05:37 PM
texlurch's Avatar
Post Has anyone used the tire "softener" treatments
My Hoosier Quick Time's are not as soft as they were new (couple years old, but good tread), and I was looking at the tire treatment in Summit, not VHT, but a softener that is supposed to make your tire stickier. Anyone ever try this, and how did you apply it, and what results?
Texlurch - 68 Camaro-LT1 w/Hot Cam, TT & TIC coming soon!
" a little spray never hurt anyone, spank you very much!"
http://camaroz28.cardomain.com/id/texlurch
Old Sep 5, 2002 | 06:08 PM
Grease's Avatar
Post
I used that stuff last year but it didn't make any difference for me, I was using worn out Goodyear RSAs. It makes the tire soft though. I was simply spraying it on but I heard you're supposed to soak the tires in that stuff for some hours to really soften up the tires.
Green 1995 Z28, 6-Speed
Best ET: 12.616 @ 110.33 mph, 1.869 60ft
Race weight: 3430lbs
Old Sep 5, 2002 | 09:29 PM
texlurch's Avatar
Post
I have seen an article somewhere that showed it being applied with a paint roller.. may be worth a shot, since new ones are $250 each..
thanks for the response
Old Sep 6, 2002 | 10:53 AM
drop top steve's Avatar
Post
I've used it in the past, put it on the night before a race, two coats. I would run the slicks past the wear holes.
I've got a tire sponser now, two sets a year!!
Old Sep 6, 2002 | 10:55 AM
blkchevyz's Avatar
Post
i used it on my drag radials once, a friend of mine had some and put it on my tires at the track... it work very well, but after a few passes their wasnt much left of the tires.
Old Sep 6, 2002 | 12:46 PM
texlurch's Avatar
Post
Thanks for the responses guys! Sounds like it is worth trying out, after I get my turbos done.
It actually hooks fairly well now, but I am looking for "just" that little bit extra!
Old Sep 6, 2002 | 09:59 PM
number77's Avatar
Post
i'm not trying to be an *** of anything, but it seems like i read somewhere that the chemicals in the tire softeners can cause the tire to fall apart without warning, has anyone else heard of this
Old Sep 7, 2002 | 01:19 AM
nd4spd200's Avatar
Post
a friend of mine put some stuff called track bite tire softner on his old e/t streets, and the tire tread came off in chunks at the track, but personally i have never used it...
Novo
Wheels and Tires
14
Oct 12, 2015 11:20 AM
scottcba1
Sep 8, 2015 09:52 AM
Beave2780
Wheels and Tires
Sep 5, 2015 06:30 PM
Latronaxe
Jul 20, 2015 12:00 PM
Slayer
Jul 4, 2015 03:06 PM
