powershifting an LT1
Old Aug 8, 2002 | 01:18 PM
simple's Avatar
Post powershifting an LT1
gas pedal stays to the floor while i use the clutch like normal
does the LT1 respond to powershifting like i've heard of some LS1's ie bent pushrods and all that good stuff
i might try this next time i go to the track
but need opinions
new best time last nightshifting at redline
14.1@101.5mph with a 2.3- 60ft
i need to slip the clutch more on my launch
97' M6, hardtop,
black EXT. gray INT.
SLP shrt thro,SPEC stage2,LS1 DS
SLP CAI,SLP Loudmouth,SS wheels
www.allaboutspeed.com/membersrides/Steve97Z28M6%20.jpg
best time 14.1@101.5mph--2.37-60'
Old Aug 9, 2002 | 02:41 AM
twistedwedge's Avatar
Post
Hell yeah, powershift that dude! Just be careful not to over-rev... When I had the t-56 in my car powershifting gained like 2 tenths and 2-3 mph.
1987 GTA- TH400 w/brake, 355, carbed, 11.3:1, TFS twisted wedge heads (non ported), Big Shot NOS, Lunati hyd roller .510/.525 lift 232/242 duration @.050, true dual 3" exhaust, hooker super comp 1 & 3/4" headers, flowmaster 2 chamber mufflers, no tailpipes, 6-pt roll bar strange 12-bolt w/ spool and 33 spline axles, BMR anti-roll bar, BMR LCA relocation brackets, BMR solid rod end panhard bar, PA tubular k-member and a-arms, PA coil over conversion, PA manual rack conversion, Weld Pro-Stars 15X10 w/28X12.5 ET Street out back, 15X3.5 out front
Best ET last year N/A,Stock suspension, on street tires, T56, stock rear end and 4.56's @ 3515 lbs: 12.46@115.1 (1/4) 8.15@90.5 (1/8)
drive it like you stole it!!
Old Aug 10, 2002 | 10:02 AM
Polecat Z's Avatar
Post
I've powershifted my car(actually every car I've ever owned) everyday for years. No Problems yet. Plus my Z28 has 104K on the odometer and the Original clutch. With my new mods, a new clutch is in the future though. I can't say how much it gains in the 1/4 since I've always done it.
Jamie Taylor
'94 Z28 M6
Mods: BBK 52mm TB, Granetelli MAF, MSD 8.5 wires, MSD coil, Bosch +4 plugs, gutted cat., In the final stages of HOT cam kit, ported heads, CSI H20 pump, Jet Hot Hooker LT's(thanks to the GP), custom 3" Y-pipe, and Custom CAI installations. It's nice being a welder, I can do all this custom tubing stuff easy!!!
1971 Datsun 240Z with V8 power. 500+rwhp
Old Aug 10, 2002 | 10:09 AM
sseeya's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by simple:
</font>
Powershifting doesn't cause bent pushrods. What causes bent pushrods, is when you miss a shift while powershifting.
SSEE YA,
Mike Glick
97 SS #2476
12.678@110.49
383 in the works!
Old Aug 10, 2002 | 03:58 PM
simple's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by sseeya:
</font>
thats what i meant
soo...
while power shifting should i start at a lil lower RPM than i normally would to help avoid over revving?
Old Aug 11, 2002 | 11:56 AM
quick91rs's Avatar
Post
1. Get an aftermarket ignition box with a rev limiter.
2. Set the rev limit 600 rpm above the rpm that you shift at.
3. Bang those gears and enjoy.
91 Camaro RS
Too many mods to list here
81 Ford F100 300 6 cyl (daily driver)
Pacific full suspension MTN bike
Pacific front suspension MTN bike
(spare tires for the Ford LOL)
http://www.quick91rs.cz28.com
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Notford95
Aug 20, 2002 01:46 AM
taner
Jul 29, 2002 03:50 PM
