Drum brakes with Draglites
Old Aug 6, 2002 | 08:57 PM
sseeya's Avatar
Post Drum brakes with Draglites
Does anybody know if 15X10 Weld Draglites will fit on drum brakes?
SSEE YA,
Mike Glick
97 SS #2476
12.678@110.49
383 in the works!
Old Aug 6, 2002 | 10:16 PM
RacinLT1's Avatar
Post
of course they will,after all,cars had drum brakes before disc.
Dirk
1997 TA A4
11.251@119.3 1.52 60',7.132@95.39 1/8
The RacinLT1
RacinLT1 pic's
Old Aug 6, 2002 | 11:41 PM
Stephen 87 IROC's Avatar
Post
13" rims may have problems fitting over 14" drums but I doubt you'll find any car with drums that a 15" rim won't fit.
Rims will fit over drums much easier than they will over disk brakes. The extra room that the calipers take up limits how far a rim can be installed.
With drums, if you didn't have inner fender/springs/shocks etc in the way, the hub of the rim could be right on the outside of the wheel (10" rim with 9" backspace).
You'll still need the longer wheel studs for Draglites since it has a thick hub.
Stephen's racing page
or check out the race car
87 IROC SuperPro race car
461 big block
Best ET on a time slip: 11.589
Best MPH on a time slip: 116
Best corrected ET: 11.079
Altitude corrected rear wheel HP: 468
Best 60 foot: 1.617
Member of the Calgary Drag Racing Association
Old Aug 7, 2002 | 09:07 AM
Pro Stock John's Avatar
Post
My friend Keith has run 15x8 Pro Stars on the back of a V6 97 and they clear no problem.
magman
Apr 15, 2016 03:08 AM
IndyZman
Oct 22, 2015 02:17 PM
Matt Dreessen
Sep 9, 2015 09:58 PM
cohopefull
Sep 8, 2015 03:22 PM
maverickmk
Sep 1, 2015 09:17 PM
