T88 turbo Q's
Old Apr 27, 2003 | 03:59 PM
2000camaroRS's Avatar
T88 turbo Q's
if i get a T88 and put it on my 2001 v6 and run low boost do u think my engine will survive, and will everything i do need to be customized? wut type of aftermarket fuel sys would i need to support that turbo?
Old Apr 27, 2003 | 05:31 PM
EddieP's Avatar
Re: T88 turbo Q's
It's probably all a mute point - a turbo that big will have a very hard time spooling on a V6.
Old Apr 27, 2003 | 05:35 PM
zturbo's Avatar
Is your motor stock?
Old Apr 27, 2003 | 07:29 PM
Brick's Avatar
What kind of stuff you been smoking? I want some of that stuff cause it must be some good **** for you to post this!!!!
Old Apr 27, 2003 | 08:30 PM
Mikael's Avatar
That turbo will most likely spool at 5600rpms on your car, so no, its not going to work.
Old Apr 27, 2003 | 11:12 PM
got_hp?'s Avatar
sounds like a dreamer, that didnt do enough research.
Old Apr 28, 2003 | 08:31 AM
got_hp?'s Avatar
Originally posted by aggiez28
i put a t-88 on my huffy and gained 200 rwhp man
i heard about that........gues appearance in FNF2?
Old Apr 28, 2003 | 03:43 PM
JordonMusser's Avatar
West South Central Moderator / Special Guest
run twin T88s for best atomization of air. since its its a V6, you can tie 3 cyl into one, and 3cyl into the other. then run the wastegates in series(like a supra) for best spooling. the key is a AVCR, it will make it boost good. Get the loudes BOV you can get, hell get 2.
oh yea, and NOS. neverforget the NOS. oh yea, and get one of those red air filters from autozone.
Old Apr 28, 2003 | 11:17 PM
got_hp?'s Avatar
i agree, but you spelled it wrong.......its NAAAAAAAWWWWWWWWWWWWSSSSSSSSSSSSSSSS
Old Apr 29, 2003 | 11:05 AM
JZ 97 SS 1500's Avatar
A T88 is a little to small for a 3.8...I would go bigger
Old Apr 30, 2003 | 03:11 PM
Chrisbequick's Avatar
A ball bearing T-100 would be the way to go. Should be good for about 1200 HP.
-Chris
Old Apr 30, 2003 | 05:09 PM
96 WS6's Avatar
Hahahaha the guy didn't even respond... he probably heard T-88 on the fast and furious and wanted one. Before you start thinking about any sort of turbos, you need a new car. The amount of you would have to put into the engine, driveline, and body/suspension would be insane to get a T-88 to work on a V6... not to mention everything would have to be custom because nobody in their right mind would ever mass produce the kit to get a T-88 to work on a V6....
On a more serious note, you are better off with some NAAWWWWSSSS.
Old Apr 30, 2003 | 06:32 PM
v7guy's Avatar
ouch, that was harsh. LOL!!
Old Apr 30, 2003 | 06:39 PM
Mikael's Avatar
The supra (although inline 6) is only 3 liters.
Old Apr 30, 2003 | 08:04 PM
not sure how a supra was brought into this, but even a real T88 would be a bit big on a Supra! a mitsu t88 is really equal to a "real" ~T72ish i believe.
